Info: Dimmer knob autoconfig?
Could somebody explain this “magic” to me ?
I’ve just bought a generic knob zigbee dimmer .
I started pairing with my ZHA on homeassistant. It paired and recognized it.
I apllied the area to my aquarium, where i also have a zigbee dimmer controling the light.
The magic is that the Homeassistant someway linked them, and it started controling that light without any further configuration !
There’s no automation configured, nothing.
Is there any place I can see this ? If I need to change something,or if I create an automation, will it cancel this magic configuration ?
Can’t help you much, but I can offer my best guess.
Your dimmer & light have been bound together via zigbee (ZHA) binding. Read up on it - there’s a few topics about it in this forum, usually happens with Ikea or Innr lights.
Thanks, I didn’t even know that exists!
So, I was looking for this configuration, went to my Zigbee network on ZHA, selected the button and edited config. As I could see, there’s no association between then. In fact, since I did not edited those configuration before, there’s only one LightGroup automatically created, and the new button is out of it.
Image is in portuguese. Luz= Light, Botão = Button, Adicionar = Add, Remover = Remove
This is the button ZHA config. Seems nothing is linked.
The interesting is that I configured another knob and it also have been linked to the same light. And I need to remove this association because this new knob will control a tuya light.
Will search for more. But thanks !
Updating the case, if someone has the same problem,
It’s cool this configuration of groups of Zigbee devices, but it seems something is broken on ZHA in HA.
The light was beng linked (although I cannot see this link) because it’s on the same default “Lighting Group” HA created automatically.
So, I created a new group and tried to add both my knob and my dimmer light. The Light I can add perfectly, but the knob refuses to enter. HA Zigbee config says it’s not part of any group. And it can’t add to the new one.
I’m looking for some information about this, found similar problems, but no solution yet.
I fanally managed to insert the knob on the New ZHA Group, using zha_toolkit.
It is working perfectly now.
But I need another help:
This knob has two modes. 1 is called app mode, that the clicks are configured on an APP and the mode 2 is the remote mode.
  • when in mode 2 (remote), it acts like a normal knob, sending zha_event for a single click, double click and turn it left/right.
    in this mode, I could not get to insert it on the group. Even with it inside the group, the link does not work.
    I tried to make an automation with it, but it is very, very slow when I turn the knob and the answer (light dimmer up/down)
  • in mode 1, the link works perfectlly, and fast.
    Single click turns the light on/off.I am trying to make an automation to use the doubleclick, but it is not sending zha_event anymore. Instead, it sends some kind of Ember event that I don´t know how to use it. Here is some lines of this event:
2025-04-22 10:22:45.827 DEBUG (Dummy-1) [bellows.ezsp.protocol] Received command messageSentHandler: {'type': <EmberOutgoingMessageType.OUTGOING_MULTICAST: 3>, 'indexOrDestination': 65533, 'apsFrame': EmberApsFrame(profileId=260, clusterId=6, sourceEndpoint=1, destinationEndpoint=255, options=<EmberApsOption.APS_OPTION_NONE: 0>, groupId=2, sequence=254), 'messageTag': 255, 'status': <EmberStatus.SUCCESS: 0>, 'messageContents': b''}
2025-04-22 10:22:45.828 DEBUG (Dummy-1) [bellows.zigbee.application] Received messageSentHandler frame with [<EmberOutgoingMessageType.OUTGOING_MULTICAST: 3>, 65533, EmberApsFrame(profileId=260, clusterId=6, sourceEndpoint=1, destinationEndpoint=255, options=<EmberApsOption.APS_OPTION_NONE: 0>, groupId=2, sequence=254), 255, <EmberStatus.SUCCESS: 0>, b'']```
