INFO Reading configuration /config/esphome/esp-laundry-temp.yaml… Failed config
Here is the code:
esphome:
esp8266:
board: d1_mini
Enable logging
logger:
Enable Home Assistant API
api:
ota:
password: “311c7e10f49543bb391883be888e5236”
wifi:
ssid: !secret wifi_ssid
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “Esp-Laundry-Temp”
password: “3HGYbjUDI9FG”
captive_portal:
web_server:
port: 80
Example configuration entry
- platform: dht
pin: D2
temperature:
name: “Laundry Temperature”
humidity:
name: “Laundry Humidity”
model: DHT11
update_interval: 60s
