Ingress access for Tandoor recipes
  1. Install Tandoor recipes and Nginx Proxy Manager add-ons and start them, no need to expose port for the Tandoor recipes add-on.
  2. Open <config>/homeassistant/addons_config/tandoor-recipes/config.yaml, add REMOTE_USER_AUTH: 1, then restart the Tandoor recipes add-on.
  3. Open Nginx Proxy Manager webui, add hass.example.com to access http://homeassistant:8123, tandoor.example.com to access http://db21ed7f-tandoor-recipes:8080. Edit the tandoor item add custom location / with configuration:
set $hass_url $scheme://hass.example.com;
auth_request /_/auth;
auth_request_set $auth_cookie $upstream_http_set_cookie;
auth_request_set $login_url $hass_url$upstream_http_location;
add_header Set-Cookie $auth_cookie always;
error_page 401 =302 $login_url;
proxy_set_header Remote-User admin;
proxy_hide_header X-Frame-Options;
add advanced configuraion:
location = /_/auth {
  internal;
  proxy_pass http://homeassistant:8123/api/ingress/_/auth;
  proxy_pass_request_body off;
  proxy_set_header Content-Length "";
  proxy_set_header X-Ingress-Name tandoor_recipes;
  proxy_set_header X-Original-URI $request_uri;
  1. Install ingress integration, add ingress configuration:
ingress:
  tandoor_recipes:
    work_mode: auth
    title: Tandoor recipes
    icon: mdi:silverware-fork-knife
    url:
      match: (\w+://)hass(\..+)
      replace: $1tandoor$2
      default: https://tandoor.example.com
Now you can access Tandoor recipes from HA sidebar without extra login. If you open http://tandoor.example.com/ when HA not logged in, it will automatically redirect to the HA login page.
Thanks, great how-to! I didn’t knew this was possible
Hi!
Thank you for this how-to! This is exactly what I needed!
Unfortunatley, it doesn’t work. If I click on the entry in the sidebar it says “ERR_NAME_NOT_RESOLVED”.
I think this is because of the db21ed7f-tandoor-recipes entry in the reverse proxy, as I can’t access this address from my local network.
Edit:
Ok, I found the error in the configuration.yaml. I use .local instead of .example.com and also no https, so I replaced your line (https://tandoor.example.com) with http://tandoor.local
Now it throws a 500 Internal Server Error. Any ideas why?
Do you know what I am doing wrong or where the problem is?
Thank you ever so much!
I trying this step by step manual … But I cannot make it work :frowning:
same ERR_NAME_NOT_RESOLVED error :frowning: could someone be more elaborate about how it make to work ?
Hello, I have doubts and I bring some information.
I am thinking to install it. I would like to have all my receipts handly managed in home assistant, as I have a tablet to move it to the kitchen. But I see that the “basic” plan can have only 10 receipts maximum. ¿is it true when we are talking to put it on HA or being host?
also, in their documentation, they specify a way to install it on HA:
I am surprised that the first step is:
the next step is to add the alexbelgium’s custom repository to your system
O.o is that you, Alexandre?
Thanks for the explanations :smiley:
Very interested in setting up tandoor with ingress access. However, your how-to does not work for my case.
I guess it may have something to do with my configuration : I access home assistant through my duckdns domain.
Do you know how to update your conf so I can access tandoor with Ingress ?
PS : the error I see when clicking on sidebar’s tandoor icon is the following :
tandoor.example.com’s server IP address could not be found.
And visiting http://tandoor.example.com/ doesn’t work either.
@JohnnyVi @rasasak @duvalale The above method is actually an authentication similar to authentik, which requires you to assign a separate domain name to tandoor. Here is the real ingress. hass_ingress/addons-for-docker-installation.md at 01534e06e527e4c4cf4f140133f991c24fde880a · lovelylain/hass_ingress · GitHub
Is there anyway to proxy the webui front end in to Home Assistant through ingress, if Tandoor Recipes is hosted separately from HA?
Supported in hass ingress v1.1.8. Refer to hass_ingress/addons-for-docker-installation.md at 4868fc9a60fdc8014fdf662c3cc3fe9db61d4d06 · lovelylain/hass_ingress · GitHub for how to configure.
I am having Tandoor running in a docker-server and am trying to embed this into home assistant via “ingest” -addon.
Unfortunately it tells me that my docker-server is rejecting connection… is there a way to config the webserver of tandoor to allow meshup?
Firefox darf diese eingebettete Seite nicht öffnen
Zu Ihrem Schutz erlaubt docker.fritz.box es Firefox nicht, diese Seite anzuzeigen, wenn sie in eine andere Seite eingebettet ist. Zur Anzeige der Seite muss diese in einem neuen Tab geöffnet werden.
I’m not sure what I’m doing wrong. I have tried to follow these instructions a few times and still can’t get to the add-on, and the local access to it stops working when I try. I’m not even sure what to look for to diagnose the problem. Is it literally example.com, or is that supposed to be replaced with my domain? I get to my HA cloud with a subdomain. Is that the problem? Do I need to get a domain just for HA?
Is anybody able to get this working?
if i follow the OP’s instructions i still cant get it to work.
i only want to access it via my local network in either a sidebar menu or as an iframe in a dashboard.
i have tandoor installed as a HA add-on and its accessible via homeassistant.local:9928
i must be doing something wrong.
do i still need an SSL certificate?
what do you mean with
its now on port 9928, if i remove that port, i have no way of accessing the UI at all
things i adjusted:
i replaced http://homeassistant:8123 with http://homeassistant.local:8123
and http://db21ed7f-tandoor-recipes:8080 with http://homeassistant.local:9928
where does this adress come from? db21ed7f-tandoor-recipes:8080
Hello guys, I make it work without the need of Nginx.
But we would need ingress and the REMOTE_USER_AUTH: 1.
I got it working adding the configuration in the configuration.yaml.
The only problem I have and I couldn’t resolve was that when I go to Tandoor the first time, I find the error of : “Oops, there is nothing here.”
But if I click Home it is working.
## INGRESS
ingress:
  tandoor_recipes:
      title: Tandoor Recipes
      icon: mdi:chef-hat
      url: http://tandoor_url_or_ip:tandoor_port
      # --- Authentication (Optional/Situational) ---
      # If Tandoor supports HTTP Basic Auth or a simple header-based login,
      # you can try to automatically log in. (Tandoor likely uses form-based login,
      # so this section might not work directly without advanced configuration.)
      headers:
          Remote-User: "your_username"
      # --- Rewrite Rules for Tandoor ---
      # These rules help fix absolute paths and redirects specific to web apps.
      rewrite:
        - mode: body
          match: /(static|api|media)/
          replace: $http_x_ingress_path/\1/
        - mode: header
          replace: $http_x_ingress_path/$1
        - mode: body
          match: \\/(static|api|media)\\/
          replace: $http_x_ingress_path\/\1\/
I got this to work without the 404 error. I did have to wipe all the data and cache of the Android app before it worked on 5G (not wifi) without errors.
Edit: The Django administration pages were not working. This is fixed now.
ingress:
  tandoor_recipes:
    work_mode: ingress
    index: /
    headers:
      Remote-User: $username
    rewrite:
      - mode: body
        match: /(static|media)/
      - mode: body
        match: ="/admin/
        replace: ="$http_x_ingress_path/admin/
      - mode: header
        match: ^/(.*)
      - mode: body
        match: <head>
        replace: <head><base href="$http_x_ingress_path/">
