Any idea what is causing this?
Logger: aiohttp.server
Source: components/hassio/ingress.py:189
First occurred: 8 January 2021, 23:50:31 (1 occurrences)
Last logged: 8 January 2021, 23:50:31
Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 118, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/hassio/ingress.py", line 57, in _handle
return await self._handle_request(request, token, path)
File "/usr/src/homeassistant/homeassistant/components/hassio/ingress.py", line 121, in _handle_request
source_header = _init_header(request, token)
File "/usr/src/homeassistant/homeassistant/components/hassio/ingress.py", line 189, in _init_header
connected_ip = ip_address(request.transport.get_extra_info("peername")[0])
TypeError: 'NoneType' object is not subscriptable
“peername” appears nowhere in my config. This error seems to occur even when I’m not looking at the frontend.
