Hi, it’s possible inhibit the binary sensor after click gpio push button.
pull down gpio → execute command → inhibit another execution for 3 sec.
this is the binary sensor
binary_sensor:
- platform: gpio
pin:
number: P9
inverted: True
on_click:
min_length: 150ms
max_length: 250ms
then:
- switch.turn_on: relay1
I think a delayed_off:
would probably work ok.
I don’t understand howto use it
Karosm
(Karosm)
May 27, 2024, 1:43pm
8
You could use template binary sensor and update it when ever you want in your code.
unfortunately I don’t have this skill
I try to find on web example or explain of that but I don’t find anything, could you help me?
You could use settle
like this:
binary_sensor:
- platform: gpio
pin:
number: P9
inverted: True
filters:
settle: 3s
on_click:
min_length: 150ms
max_length: 250ms
then:
This means that the 3 seconds inhibit period will be counted from the last button press, though, and not just from last successful button press. If you want the latter, you’ll probably have to measure times yourself in a lambda action.
Something along these lines:
time:
- platform: sntp
binary_sensor:
- platform: gpio
pin:
number: P9
inverted: True
on_click:
min_length: 150ms
max_length: 250ms
then:
- lambda: |-
const int INHIBIT_SECS = 3;
static int next_click = 0;
auto time = id(sntp_time).now();
if ( time.timestamp > next_click ) {
id(relay1).turn_on();
next_click = time.timestamp + INHIBIT_SECS;
thanks so much!
the lambda script work great.
