Initial effect for neopixel light
Hi, newbe here…
I have an esp32 with ESPHome, with a connected neopixel led strip, and I defined an effect. Everything good so far (can control it with HomeAssistant), but…
  • when i switch it on
  • select the efect
  • turn it off
  • turn it on again
The effect is lost (null).
How can I make my effect to be active by default, or restored after switching off/on
Been googling end experimenting for an hour without success…
A good tip would be apreciated!
Thanks, Hans.
You can use an automation with on_turn_on for the trigger and light.control for the action.
light:
  - platform: ...
    on_turn_on:
      then:
        - light.control:
          effect: your_effect
Thanks Mike! That almost worked, but I had to indent some lines more, don’t understand why…
This is what have now:
light:
  - platform: neopixelbus
    variant: WS2813
    type: GRB
    pin: GPIO16
    num_leds: 12
    default_transition_length : 0s
    on_turn_on:
      then:
        - light.control:
            effect: "My Custom Effect"
    on_turn_off:
    - logger.log: "Light Turned Off!"
    effects:
        - addressable_lambda:
            name: "My Custom Effect"
Could you share some details on how you configured your actual custom effect please?
You can find example effects in the esphome docs.
https://esphome.io/components/light/#light-effects
