The HA is hard wired directly into my Cox modem/router. I have completely disconnected and unplugged my other router to avoid confusion. There is no VPN.
Attached is what i get when I ping homeassistant.local -4 in CMD
It does not complete the scan. all I get is what I sent then the screen disappears.
My instincts tells me this is network issue and not a HA issue. What is the model of the COX device? I ask because there may be way to delete the static IP devices.
Does this work now from a browser?
http://192.168.0.51:8123
it does not. i tried two different web browsers but both say it refused to connect.
Same with http://homeassistant.local:8123 ?
both don’t work ![]()
Your HA is talking to your network, we know that. What is your installation setup? Is it Docker as I remember?
What device is hosting HA?
Sorry have been answering multiple threads. HA green… DUH
haha no worries!
I am unsure if IP forwarding was already enabled.
Your router isn’t making the connection between HA and your PC so I think its a router setting. Can you disable port forwarding?
COX routers are a pain in the butt ![]()
This would be my last resort
