I am really hoping this is a simple fix and I am just doing something simple wrong. I am running Home Assistant on my Synology NAS using Docker (Followed the instructions here). I have it up and the GUI is accessible (It even auto discovers a few things). However, when I add the configuration data for my envisalink evl-4 it appears that the entire setup crashes. Currently the only thing I really want use Home Assistant for is the Envisalink module. I may try to add other things later I can get this resolved. I apologize for such a basic setup question but I am very new to this type of thing.
My current configuration.yaml is below. With that configuration Home Assistant never becomes reachable after starting the container. When I replace that with the original configuration.yaml it comes right up within a few seconds after starting the container.
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: xx.xxxx
longitude: -xx.xxxx
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: xxx
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/New_York
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
# Uncomment this to add a password (recommended!)
# api_password: PASSWORD
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Track the sun
sun:
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google
#Envisalink Config
envisalink:
host: 192.168.10.6
panel_type: DSC
user_name: user
password: user
code: 'xxxx'
port: 4025
evl_version: 4
keepalive_interval: 60
zonedump_interval: 30
panic_type: Police
zones:
01:
type: 'opening'
02:
type: 'opening'
03:
name: 'Back Door & Breakfast Windows'
type: 'opening'
04:
type: 'opening'
05:
type: 'opening'
06:
name: 'Living Room Windows'
type: 'opening'
partitions:
1:
group: !include groups.yaml
script: !include scripts.yaml
