As it is today, if I have an input_boolean, input_slider, input_select etc, the default on HA when started is either a) the first/minimum/last saved value 2) the value if you use “Initial”
The problem with this is, HA often re-starts with an unwanted value. For example, if I have an input_slider for brightness on a light switch and I don’t use “initial”, it uses the minimum value (some cases, it uses the last known setting in the DB, but it’s not consistent). If I use “initial”, it forgets my last used preference before the restart in favor of the “initial” value. This creates issues, when using input components for a “user settings” type screen.
I’m suggesting the following:
- HA checks the database for the last used state and uses that if present
- If no state is in the DB, use “initial”
- If no state in the DB and no “initial” defined in the config, then use the first/minimum value
