I see this request a lot and I still don’t understand it. The important data is how much you use an hour/day/month not the absolute value.
But if you feel the need for it then the easiest way is to feed your sensor to a utility meter helper (with no cycle specified, so it counts up forever), and use the utility meter calibration service in Developer Tools → Services to set the value the same as your meter.
