Initialization, impossible to access to homeassistant.local:8123
Hello, I’m trying to install HA with virtual box.
I think everything is functional except the fact I can’t access to …:8123.
I can’t find in my DHCP Router the IP address. But the http://homeassistant.local:4357 works.
If you have an idea, I’m on MAC OS.
Thanks in advance.!
It’s using IPv6.
Ah ok thank you do you have any link on how use IPv6? I tried to find on the Forum or Google but I cant find something helpful for me.
:pray:
Hi VirAlex, were you able to figure out how to use IPv4 instead of 6? I’m having the same issue
Settings > System > Network
Tom_I - thanks for the quick reply. Unfortunately I’m unable to get past the welcome screen below and I think I’d need to in order to get to where your screeshot is from. Like VirAlex, the connection says it’s working when I go to local:4357. I tried changing the settings in nmcli but had no luck there either.
Try turning off IPv6 support in your DHCP server and then restart the Home Assistant Host machine.
My problem is similar but it seems its not using either ipv4 or ipv6. How would I turn it on for 4. Im using virtual box on windows
Did you set your network adapter to bridged in Virtualbox ?
