Initialization of array of array globals
Hi all!
I’m creating a variable in globals with:
globals:
  - id: timers
    type: long[7][2]
    initial_value: '{{25200, 72900}, {25200, 72900}, {25200, 72900}, {25200, 72900}, {25200, 73800}, {27000, 73800}, {28800, 72900}}'
but it seems the compiler has trouble digesting the initializer
/config/esphome/foo.yaml:146:175: error: no matching function for call to ‘esphome::globals::RestoringGlobalsComponent<long int [7][2]>::RestoringGlobalsComponent()’
any suggestions?
Something similar if I use the globals.set action like
on_...:
  - globals.set:
      value: '10'
with
IDs must only consist of upper/lowercase characters, the underscorecharacter and numbers. The character ‘[’ cannot be used.
Are arrays supported as globals at all? :thinking:
I missed an extra brace level for the initialization. This compiles:
globals:
  - id: timers
    type: unsigned long[7][2]
    initial_value: '{{{25200, 72900}, {25200, 72900}, {25200, 72900}, {25200, 72900}, {25200, 73800}, {27000, 73800}, {28800, 72900}}}'
Thanks for sharing back the solution.
Curious what your use case is (something to do with different timers;), and syntax for accessing individual values of the array in a lambda (I assume it is something similar to timers[3][3]?)
Cheers.
Yes, correct…
It’s a custom night light with a couple of timers based on day of the week and time of the day…
I am trying to do a similar thing:
        - globals.set:
            value: !lambda return id(o_a_c_1).current_values.get_red()* id(o_a_c_1).current_values.get_brightness() * 255;
but when compiling I get the error above .
this is the global variable definition:
# Color Variables
  - id: profile_colorvar_a_i_a_r
    type: int[$profiles_num][$colorvar_num]
    restore_value: yes
Any clue? TX
One step closer.
lambda must be used to update global arrays (according to an issue in esphome’s github)
with this
    on_state:
      then:
        - lambda:  profile_colorvar_a_o_a_r[0][0] = id(o_a_c_1).current_values.get_red()* id(o_a_c_1).current_values.get_brightness() * 255;
compiler now throws:
/config/esphome/esphome-web-b658a0.yaml: In lambda function:
/config/esphome/esphome-web-b658a0.yaml:431:34: error: no match for ‘operator[]’ (operand types are ‘esphome::globals::RestoringGlobalsComponent<int [6][4]>’ and ‘int’)
*** [/data/the-circle/.pioenvs/the-circle/src/main.cpp.o] Error 1
a “No match for operator[] error”
looks like the array is interpreted as a list…
