Initiating a conversation by proactively asking a question
Hi there,
I recently purchased the Voice Preview Edition. I was excited that in 2025.4, HA added the ability for the device to proactively start listening.
I wanted to create a very simple automation or script that:
  1. Asks a question, like “Do you want me to turn the lights on?”
  2. Starts listening
  3. If the user says yes/sure/ok, turn the lights on
I will incorporate this more contextually into my automations, but for now I just wanted to get it to work.
I am open to using either OpenAI (cloud) or local.
I just haven’t been able to find a simple example.
Thanks so much in advance!
Matt
Nothing’s simple. However…
Don’t know if they work! :grin:
Thanks @jackjourneyman .
In this example, I’m unsure how to tell it to call a script (that turns a light off) in the event the user responds in the affirmative.
automation:
  - alias: 'Proactive Energy Advice'
      - platform: numeric_state
        entity_id: sensor.total_energy_consumption
        above: 500  # kWh threshold
      - service: conversation.process
          text: 'Your energy consumption is unusually high. Would you like recommendations for reducing usage?'
Well… I’ve never tried this either. Are you familiar with custom sentences and intent scripts?
The custom sentence might be:
language: "en"
intents:
  CustomYes:
      - sentences:
          - "[That would be a] yes"
          - "( OK | okay ) [go ahead] [if you like] [go on then]"
And the intent script might be:
CustomYes:
    - service: tts.picotts_say
      metadata: {}
        cache: false
        entity_id: media_player.living_room
        message: Turning off the living room lights
    - service: switch.turn_off
        entity_id: switch.all_living_room_lights
Two problems with this:
  • You still have to say the wake word before “Yes”
  • How can you make sure the “Yes” is part of the same conversation as the original question.
More research needed. :grin:
@jackjourneyman thank you sir for the replies! I’m not, this is actually my first foray into voice AND LLMs. I have a lot to learn. I appreciate the links. I’ll read up!
Cheers!
Matt
You can start a conversation with Home assistant PE using action: assist_satellite.start_covversation . It work perfectly with Gemini and Open Ai.
The post I created was before that you can effectively use start_conversation with PE
