I Inkbird BT thermometer. When a probe is not plugged in to one of the available slots the temp will read 32 °F. I was trying to create a sensor template that would show “Off” is the value was = to 32 otherwise show the current temp. I been trying different things but haven’t got it to work. One example is below. Thank you!
The way to build these it to go into developer tools / templates and put your value template expression in there, then you can work on it until you get it right,
This may be a simpler approach, just use the availability_template.
PeteRage, thank you for pointing me in the right direction.
I have never used the Developer Tools, Template before. I got it working they way I wanted, using the template below.
