I think I finally have my Inkbird IBT-4XS all set up and working well now. I also had the drop outs, but I saw that ocassionally my ESP32 wouldn’t get updates for jjst over 60 seconds and so the script would set the sensor values to zero. I just changed the delay value in the script to 90s and it all works fine for me now.
I also switched to Fahrenheit by just updating the maths on each probe (example below) and also made sure that if the value was 0C then the sensor would also report 0F rather than 32F.
Full script below with the usual wifi, esp32 and ap details ommitted:
if (probe0 < 60000 and probe0 != 0) {
id(ble_sensor_1).publish_state(probe0 / 10.0 * (9.0/5.0) + 32.0);
} else {
id(ble_sensor_1).publish_state(0);
Full ESP32 config (minus the usual wifi, ota and ap details):
esphome:
on_boot:
priority: -10
then:
- lambda: |-
id(ble_sensor_1).publish_state(false);
id(ble_sensor_2).publish_state(false);
id(ble_sensor_3).publish_state(false);
id(ble_sensor_4).publish_state(false);
script:
- id: timer
then:
- delay: 90s
- lambda: |-
esp32_ble_tracker:
on_ble_advertise:
- mac_address: xx:xx:xx:xx:xx
then:
- script.stop: timer
- lambda: |-
if (x.get_name() != "iBBQ") return;
ESP_LOGI("ble_adv", "New BLE device");
ESP_LOGI("ble_adv", " address: %s", x.address_str().c_str());
ESP_LOGI("ble_adv", " name: %s", x.get_name().c_str());
ESP_LOGI("ble_adv", " Advertised service UUIDs:");
for (auto uuid : x.get_service_uuids()) {
ESP_LOGI("ble_adv", " - %s", uuid.to_string().c_str());
ESP_LOGI("ble_adv", " Advertised service data:");
for (auto data : x.get_service_datas()) {
ESP_LOGI("ble_adv", " - %s: (length %i)", data.uuid.to_string().c_str(), data.data.size());
ESP_LOGI("ble_adv", " Advertised manufacturer data:");
for (auto data : x.get_manufacturer_datas()) {
ESP_LOGI("ble_adv", " - %s: (%s)", data.uuid.to_string().c_str(), hexencode(data.data).c_str());
if (data.uuid.contains(0, 0)) {
int probe0 = (data.data[9] << 8) + data.data[8];
int probe1 = (data.data[11] << 8) + data.data[10];
int probe2 = (data.data[13] << 8) + data.data[12];
int probe3 = (data.data[15] << 8) + data.data[14];
ESP_LOGI("ble_data", " - %f %f", probe0 / 10.0, probe1 / 10.0);
} else {
if (probe1 < 60000 and probe1 != 0) {
id(ble_sensor_2).publish_state(probe1 / 10.0 * (9.0/5.0) + 32.0);
} else {
id(ble_sensor_2).publish_state(0);
if (probe2 < 60000 and probe2 != 0) {
id(ble_sensor_3).publish_state(probe2 / 10.0 * (9.0/5.0) + 32.0);
} else {
id(ble_sensor_3).publish_state(0);
if (probe3 < 60000 and probe3 != 0) {
id(ble_sensor_4).publish_state(probe3 / 10.0 * (9.0/5.0) + 32.0);
} else {
id(ble_sensor_4).publish_state(0);
- script.execute: timer
name: "iBBQ Temperature Probe 1"
unit_of_measurement: "°F"
accuracy_decimals: 0
name: "iBBQ Temperature Probe 2"
name: "iBBQ Temperature Probe 3"
name: "iBBQ Temperature Probe 4"
silvrr
September 2, 2022, 2:35pm
64
Thanks for posting this. I was using the filter option on the sensor and just living with 32=0. Nice to have this little tweak!
phdelodder
(Philippe Delodder)
September 20, 2022, 6:35am
65
Could it be possible to also share your automation?
nau
(Anton)
September 20, 2022, 8:53am
66
Sure.
- id: '123'
alias: Grill notification
description: ''
- platform: state
entity_id: sensor.target_alert_temp_probe_1
to: Alert
- platform: state
entity_id: sensor.target_alert_temp_probe_2
to: Alert
- platform: state
entity_id: sensor.target_alert_temp_probe_3
to: Alert
- platform: state
entity_id: sensor.target_alert_temp_probe_4
to: Alert
condition: []
- service: notify.telegram_anton
message: Grill needs your attention.
SerpikoIT
(Serpiko It)
October 25, 2022, 5:57am
67
good morning to me from this error if I insert the first part in the yaml of the esp32
Please remove the platform
key from the [esphome] block. You’re already using the new style with the [esp32] block.
SerpikoIT
(Serpiko It)
October 27, 2022, 12:36pm
68
Hello I have been trying for a few days to be able to use ESP32Home with my inkbird, I installed the config file on my thermometer as described in the first topic, then I created my sensor file and the entities but it gives me an error telling me that the entities do not they have a unique id, I would like to clarify that the entities I imported from an old configuration that I had using MQTT by replacing only the sensor name.
Below I put my files and if you kindly tell me how I could solve it I would be grateful.
File Config.ymal
esphome:
on_boot:
priority: -10
then:
- lambda: |-
script:
- id: timer
then:
- delay: 60s
- lambda: |-
esp32_ble_tracker:
on_ble_advertise:
- mac_address: FC:45:C3:0D:38:A8
then:
- lambda: |-
if (probe0 < 60000) {
id(ble_sensor_1).publish_state(probe0 / 10.0);
} else {
if (probe1 < 60000) {
id(ble_sensor_2).publish_state(probe1 / 10.0);
} else {
name: "iBBQ Temperatura Sonda 1"
unit_of_measurement: "°C"
name: "iBBQ Temperatura Sonda 2"
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "7dCYOVOF4fgpr5GAoArrfSSIxX/4fjQht7N49mLPok4="
ota:
password: "b8df93a21ac091fb8d49f3599c3dd84d"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esp32-Cucina Fallback Hotspot"
password: "PwHj14ftDP7x"
captive_portal:
File Sensor.ymal
sensors:
owen_temp_alert:
value_template: >-
{% if (states.sensor.ibbq_temperatura_sonda_1.state | int) < (states.input_number.owen_temp_low.state | int) or (states.sensor.ibbq_temperatura_sonda_1.state | int) > (states.input_number.owen_temp_high.state | int) %}
Alert
{% else %}
Normal
{% endif %}
friendly_name: Owen Temp Alert
icon_template: >-
mdi:alert-circle
{% else %}
mdi:alert-circle-check
{% endif %}
owen_target_temp_alert:
value_template: >-
{% if (states.sensor.ibbq_temperatura_sonda_1.state | int) >= (states.input_number.owen_target_temp.state | int) %}
Alert
{% else %}
Normal
{% endif %}
friendly_name: Owen Target Temp Alert
icon_template: >-
mdi:alert-circle
{% else %}
{% endif %}
meat_target_temp_alert:
value_template: >-
{% if (states.sensor.ibbq_temperatura_sonda_2.state | int) >= (states.input_number.meat_target_temp.state | int) %}
Alert
{% else %}
Normal
{% endif %}
friendly_name: Meat Target Temp Alert
icon_template: >-
mdi:alert-circle
{% else %}
{% endif %}
meat_temp_alert:
value_template: >-
{% if (states.sensor.ibbq_temperatura_sonda_2.state | int) < (states.input_number.meat_temp_low.state | int) or (states.sensor.ibbq_temperatura_sonda_2.state | int) > (states.input_number.meat_temp_high.state | int) %}
Alert
{% else %}
Normal
{% endif %}
friendly_name: Meat Temp Alert
icon_template: >-
mdi:alert-circle
{% else %}
{% endif %}
I believe nothing is missing
sopvkore
(Valentin Korenjak)
November 14, 2022, 5:21pm
69
Thanks for sharing your experiences. I had a similar situation - an IBT-2x that is being reconginzed as xBBQ publishing temperature measurements with UUID 0x0001. The changes are (obviously) two:
Recognizing the device as xBBQ:
if (x.get_name() != "xBBQ") return;
Manufacturer datas for the temperature reading UUID is different:
if (data.uuid.contains(1, 0)) {
@paddy0174 Could you perhaps add a note to your original post about this variation as it is obviously getting lost down there? (btw. I’ve figured out the two changes by myself prior to finding the relevant solution already discussed here)
aherbjornsen
(Anders Herbjornsen)
November 15, 2022, 1:04pm
70
I might be missing something, but Inkbird thermometers are now directly supported as an integration:
If you want to use an ESP32 to extend the range, you should be able to just use the new bluetooth_proxy component in ESPHome:
So instead of all the complicated stuff in the original post. Just adding “bluetooth_proxy:” to your ESPHome config should do the trick, and the sensors should automatically be discovered.
SerpikoIT
(Serpiko It)
November 17, 2022, 8:07am
71
good morning how is it possible to read the degrees even after the . like 29.2°C and not just 29?
I added precision_decimals: 1
to my sensor configuration
but it gives me this error
Invalid config for [sensor.template]: [accuracy_decimals] is an invalid option for [sensor.template]. Check: sensor.template->sensors->owen_temp_alert->accuracy_decimals. (See ?, line ?).
under my configuration
sensors:
owen_temp_alert:
value_template: >-
{% if (states.sensor.ibt_2x_tempc.state | int) < (states.input_number.owen_temp_low.state | int) or (states.sensor.ibt_2x_tempc.state | int) > (states.input_number.owen_temp_high.state | int) %}
Alert
{% else %}
Normal
{% endif %}
icon_template: >-
mdi:alert-circle
{% else %}
{% endif %}
accuracy_decimals: 1
value_template: >-
{% if (states.sensor.ibt_2x_tempc.state | int) >= (states.input_number.owen_target_temp.state | int) %}
Alert
{% else %}
Normal
{% endif %}
icon_template: >-
mdi:alert-circle
{% else %}
{% endif %}
value_template: >-
{% if (states.sensor.ibt_2x_tempc2.state | int) >= (states.input_number.meat_target_temp.state | int) %}
Alert
{% else %}
Normal
{% endif %}
icon_template: >-
mdi:alert-circle
{% else %}
{% endif %}
meat_temp_alert:
value_template: >-
{% if (states.sensor.ibt_2x_tempc2.state | int) < (states.input_number.meat_temp_low.state | int) or (states.sensor.ibt_2x_tempc2.state | int) > (states.input_number.meat_temp_high.state | int) %}
Alert
{% else %}
Normal
{% endif %}
icon_template: >-
mdi:alert-circle
{% else %}
{% endif %}
aherbjornsen
November 18, 2022, 9:18am
72
Well. You are converting everything to integers using “| int” in your templates, so there will be no decimals.
You need to use floating point (| float) and the “round” function (| round(1)) in order to get what you want.
Also - I do not believe “accuracy_decimals” is valid for a platform sensor.
SerpikoIT
(Serpiko It)
November 18, 2022, 4:02pm
73
would you help make me understand with some example in my setup
SerpikoIT
(Serpiko It)
November 18, 2022, 6:40pm
76
hello I tried to modify my config adding your configurations but it gives me this error
Invalid config for [sensor.template]: [grill_alert_low] is an invalid option for [sensor.template]. Check: sensor.template->sensors->grill_alert_high->grill_alert_low. (See ?, line ?).
sensors:
owen_temp_alert:
value_template: >-
Alert
{% else %}
Normal
{% endif %}
icon_template: >-
mdi:alert-circle
{% else %}
{% endif %}
value_template: >-
Alert
{% else %}
Normal
{% endif %}
icon_template: >-
mdi:alert-circle
{% else %}
{% endif %}
value_template: >-
Alert
{% else %}
Normal
{% endif %}
icon_template: >-
mdi:alert-circle
{% else %}
{% endif %}
meat_temp_alert:
value_template: >-
Alert
{% else %}
Normal
{% endif %}
icon_template: >-
mdi:alert-circle
{% else %}
{% endif %}
grill_alert_low:
friendly_name: "Sonda 1 Low Temp"
unit_of_measurement: "ºC"
value_template: "{{ (((states('input_number.owen_temp_low') | float)))|round(1)}}"
grill_alert_high:
friendly_name: "Sonda 1 High Temp"
value_template: "{{ (((states('input_number.owen_temp_high') | float)))|round(1)}}"
grill_alert_low:
friendly_name: "Sonda 2 Low Temp"
value_template: "{{ (((states('input_number.meat_temp_low') | float)))|round(1)}}"
grill_alert_high:
friendly_name: "Sonda 2 High Temp"
value_template: "{{ (((states('input_number.meat_temp_high') | float)))|round(1)}}"
I understand that grill_alert_low is repeated twice but it’s the two probes how can I do for the two probes?
Mark53
(Mark53)
November 21, 2022, 12:30am
77
Thank you @aherbjornsen . Wow so easy and quick to setup with Bluetooth Proxy.
Is it possible to obtain the Inkbird battery level?
dormani
December 25, 2022, 11:55pm
78
Were you able to get the battery status coming across for the Inkbird. If so would you mind sharing. I am running a IBT-4XS. Thanks
Pernod
December 27, 2022, 1:07am
80
Thanks for this, it was driving me nuts. I totally missed that typo in the tutorial.
Theetjuh
(Mathé)
January 14, 2023, 11:07am
81
I had the bluetooth proxy in passive mode, but it couldn’t see my IBT-4XS.
I have changed to use active mode and HA found it immediately.
Trilis29
(Trilis29)
March 20, 2023, 3:30pm
82
can you share automation?
