Inkbird Integration: add IHT-2pb Support?
Is there any chance to add Support for the IHT-2pb bluetooth BBC thermometer?
BR
Thomas
I would like to second this request.
If I can provide any necessary data, I’m glad to do so. But you would need to advise me, as I have no experience in this field.
If you have a ESP32 device sitting around, I have created an ESPHome project to add Inkbird-ITH-2PB to home assistant.
First of all: Sry for the late reply. I had my notifications settings wrong…
Second: Thank you very much for this project. On a “standard” esp32 development board (like this) it worked right out of the box.
On a esp32-c3 board I had to use another .yaml.
esp32-c3 yaml
esphome:
  friendly_name: testEsp32C3
  on_boot: #this is to avoid slow startup time because of BT and WiFi "interactions?" , check https://github.com/esphome/issues/issues/2941#issuecomment-1331851692
    priority: 250
    then:
      #- delay: 15s
      - wait_until:
          condition:
            wifi.connected:
      #- lambda: |-
      #    id(ble_tracker).set_scan_continuous(true);
      #    id(ble_tracker).start_scan();
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: arduino
    #type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: !secret encryption_key
ota:
  password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: !secret wifi_fallback_ssid
    password: !secret wifi_fallback_password
captive_portal:
bluetooth_proxy:
  active: true
esp32_ble_tracker:
  #scan_parameters:
  #  continuous: false
  scan_parameters:
    interval: 1100ms
    window: 1100ms
    active: true
# Inkbird handheld thermometer with 1 manual probe and 2 external probes
ble_client:
- mac_address: !secret ble_mac_address_IHT2PB
  on_connect:
    then:
      - lambda: |-
          ESP_LOGD("ble_client_lambda", "Connected to BLE device");
          id(inkbird_IHT_2PB_connected).publish_state(true);
      # We need to add a small delay because on_connect is triggered before the device is fully connected
      # see https://github.com/esphome/issues/issues/4153
      # But even with a 10ms delay it doesn't seem to work
      # - delay: 10ms
      # - script.execute: activate_temperature_notifications
  on_disconnect:
    then:
      - lambda: |-
          ESP_LOGD("ble_client_lambda", "Disconnected from BLE device");
          id(inkbird_IHT_2PB_connected).publish_state(false);
script:
- id: activate_temperature_notifications
  then:
    - ble_client.ble_write:
        service_uuid: 0000ffe0-0000-1000-8000-00805f9b34fb
        characteristic_uuid: 0000ffe9-0000-1000-8000-00805f9b34fb
        value: [0x55, 0xAA, 0x19, 0x01, 0x00, 0x19]
        characteristic_uuid: 0000ffe4-0000-1000-8000-00805f9b34fb
        value: [0x55, 0xAA, 0x1A, 0x01, 0x00, 0x1A]
        # We get the error "Characteristic 0000FFE4-0000-1000-8000-00805F9B34FB does not allow writing"
        # but this write is necessary to get temperature notifications
switch:
- platform: ble_client
  ble_client_id: inkbird_IHT_2PB_ble
  name: "Inkbird IHT-2PB enable"
button:
  name: "Inkbird IHT-2PB notification"
  on_press:
binary_sensor:
  name: "Inkbird IHT-2PB connected"
  icon: mdi:bluetooth-connect
  name: "Inkbird IHT-2PB probe manual"
  icon: mdi:thermometer-probe
  unit_of_measurement: "°C"
  accuracy_decimals: 1
  device_class: "temperature"
  state_class: "measurement"
  name: "Inkbird IHT-2PB probe 1"
  name: "Inkbird IHT-2PB probe 2"
  type: characteristic
  name: "Inkbird IHT-2PB last probe data"
  notify: true
  lambda: |-
    if (x[2] != 2 && x[2] != 4 && x[2] != 6) {
      return -1.0;
    uint8_t probeNr = x[2] / 2;
    float temperature;
    if (x[4] >= 254) {
        // negative
        temperature = (float) ((255 * (x[4] - 255)) + (x[5]-255)) / 10;
    } else if (x[4] <= 11){
        //positive
        temperature = (float) ((255 * x[4]) + x[5]) / 10;
    } else {
        return -1.0;
    if (probeNr == 1) {
      id(inkbird_IHT_2PB_probe0).publish_state(temperature);
    } else if (probeNr == 2) {
      id(inkbird_IHT_2PB_probe1).publish_state(temperature);
    } else if (probeNr == 3) {
      id(inkbird_IHT_2PB_probe2).publish_state(temperature);
    return (float)probeNr;
I think the main difference was to wait until wifi is connected before doing anything else:
esphome:
    priority: 250
    then:
      #- delay: 15s
      - wait_until:
          condition:
            wifi.connected:
and that I had to use arduino as framework
esp32:
  framework:
    type: arduino
I still had to flash it 2-3 times before it worked (had no temperature readings). Right now I have no issues with it (only ~6 h of testing. I will report back after ~1 month).
I don’t have a esp32-c3 available to test at the moment. But if it works for you then you can open a PR on github.
