Inkbird integration IBS-TH2
I have the Inkbird integration installed and it has worked in the past. I was able to see the temperature and humidity as well as the battery status. When I look at the device and entities now, it shows Battery, Humidity and Temperature as “Not provided”. When I click on the entity, it tells me that this entity is no longer being provided by the inkbird integration. What am I missing here? What’s the point of the integration if it doesn’t provded these entities?
I’ve reloaded the integration, but no change. What do I need to do to have HA give me the info that I am looking for? When I look at the thermostat app, the info is being provided to the app, so the thermometer is working.
Thank you.
