Inkbird IVC-001W Fan Controller
I recently acquired a duct booster fan to exhaust my coat closet / server closet. It came with a Tuya compatible module but there wasn’t any support out there for it so I ended up replacing the WBR3 with a ESP12F and ESPHOME firmware. I didn’t add support for all the features this thing comes with because I deemed them unnecessary. I added the PID component for temperature control because I wasn’t satisfied with the bang bang controller built into the unit. This firmware allows me to constantly adjust the set point so that it’s +5ºF above the temperature outside the closet.
If anyone else out there has this fan and wants to integrate it into Home Assistant this firmware config could be useful. I’ve left off some of the basics here, but if you just create a new project in ESPHOME builder it will add that stuff for you automatically.
captive_portal:
uart:
  rx_pin: GPIO3
  tx_pin: GPIO1
  baud_rate: 9600
time:
  - platform: homeassistant
# Register the Tuya MCU connection
tuya:
  time_id: my_time
  on_datapoint_update:
    - sensor_datapoint: 16
      datapoint_type: uint
      then:
        lambda: !lambda |-
          int16_t min_temp_local = (int16_t)(0xFFFF & x);
          int16_t max_temp_local = (int16_t)(0xFFFF & (x >> 16));
          if ((float)min_temp_local/10.0f != id(min_temp_store).state)
            id(min_temp_store).publish_state(min_temp_local/10.0f);
          if ((float)max_temp_local/10.0f != id(max_temp_store).state)
            id(max_temp_store).publish_state(max_temp_local/10.0f);
    - sensor_datapoint: 101
      datapoint_type: raw
      then:
        lambda: !lambda |-
          if(id(manual_fan_speed_store).state != x[0])
            id(manual_fan_speed_store).publish_state(x[0]);
    - sensor_datapoint: 102
      then:
        lambda: !lambda |-
          uint16_t min_humid_local = (uint16_t)(0xFFFF & x);
          uint16_t max_humid_local = (uint16_t)(0xFFFF & (x >> 16));
          if ((float)min_humid_local/10.0f != id(min_humid_store).state)
            id(min_humid_store).publish_state(min_humid_local/10.0f);
          if ((float)max_humid_local/10.0f != id(max_humid_store).state)
            id(max_humid_store).publish_state(max_humid_local/10.0f);
    # Byte0 indicates the working mode (Bit7~BIT4 indicates the mode), Bit3 indicates whether the fan is running (0 indicates off,  1 indicates running); Bit2 indicates the temperature scale\\n
    # Byte1~2 indicates the current temperature value ℃,
    # Byte3~4 indicates the current temperature value ℉
    # Byte5~6 indicates the current humidity
    # BYTE7: Wind speed\\n
    # BYTE8~9: High temperature preset value
    # BYTE10~11: Low temperature preset value
    # BYTE12~13: High humidity preset value
    # BYTE14~15: Low humidity preset value
    # BYTE16: Alarm status
    # BYTE17: Alarm upload flag (0: not upload; 1: upload)
    # BYTE18~19: Fan running time
    - sensor_datapoint: 132
      datapoint_type: raw
      then:
        lambda: !lambda |-
          uint8_t mode = x[0] >> 4;
          switch(mode) {
            case 0:
              id(operating_mode).publish_state("Auto");
              break;
            case 1:
              id(operating_mode).publish_state("Manual");
              break;
            case 2:
              id(operating_mode).publish_state("Timer");
              break;
          uint8_t fan_running = (x[0] & 0b1000) > 0;
          id(fan_status).publish_state(fan_running);
          uint8_t temp_scale = (x[0] & 0b100) > 0;
          if(temp_scale) id(temp_unit).publish_state("F");
          else id(temp_unit).publish_state("C");
          uint16_t curr_temp_c_int = x[1] * 256;
          curr_temp_c_int += x[2];
          float curr_temp_c = (int16_t)curr_temp_c_int;
          id(temp_c).publish_state(curr_temp_c/10.0f);
          uint16_t curr_temp_f_int = x[3] * 256;
          curr_temp_f_int += x[4];
          float curr_temp_f = (int16_t)curr_temp_f_int;
          id(temp_f).publish_state(curr_temp_f/10.0f);
          uint16_t curr_humid_int = x[5] * 256;
          curr_humid_int += x[6];
          float curr_humid = (int16_t)curr_humid_int;
          id(humid).publish_state(curr_humid/10.0f);
          uint8_t fan_speed = x[7];
          id(curr_fan_speed).publish_state(fan_speed);
text_sensor:
binary_sensor:
    unit_of_measurement: "°C"
    icon: "mdi:thermometer"
    device_class: temperature
    state_class: measurement
    unit_of_measurement: "°F"
    unit_of_measurement: "%"
    icon: "mdi:water-percent"
    device_class: humidity
    icon: "mdi:speedometer"
  - platform: pid
    name: "PID Climate Result"
    type: RESULT
  - platform: pid
    name: "PID Climate Error"
    type: ERROR
  - platform: pid
    name: "PID Climate Proportional"
    type: PROPORTIONAL
  - platform: pid
    name: "PID Climate Integral"
    type: INTEGRAL
  - platform: pid
    name: "PID Climate Derivative"
    type: DERIVATIVE
  - platform: pid
    name: "PID Climate KP"
    type: KP
  - platform: pid
    name: "PID Climate KI"
    type: KI
  - platform: pid
    name: "PID Climate KD"
    type: KD
# Power switch
switch:
  - platform: "tuya"
    switch_datapoint: 1
    inverted: True
  - platform: "tuya"
    switch_datapoint: 107
  - platform: "tuya"
    switch_datapoint: 109
    name: "Disable Max Temperature"
    lambda: !lambda |-
      return (id(max_temp_store).state == 0x7FFF);
    turn_on_action:
      then:
        lambda: !lambda |-
          id(max_temp_store).publish_state(0x7FFF);
    turn_off_action:
      then:
        lambda: !lambda |-
          id(max_temp_store).publish_state(750);
    name: "Disable Min Temperature"
    lambda: !lambda |-
      return (id(min_temp_store).state == 0x7FFF);
    turn_on_action:
      then:
        lambda: !lambda |-
          id(min_temp_store).publish_state(0x7FFF);
    turn_off_action:
      then:
        lambda: !lambda |-
          id(min_temp_store).publish_state(350);
    name: "Disable Max Humidity"
    lambda: !lambda |-
      return (id(max_humid_store).state == 0x7FFF);
    turn_on_action:
      then:
        lambda: !lambda |-
          id(max_humid_store).publish_state(0x7FFF);
    turn_off_action:
      then:
        lambda: !lambda |-
          id(max_humid_store).publish_state(600);
    name: "Disable Min Humidity"
    lambda: !lambda |-
      return (id(min_humid_store).state == 0x7FFF);
    turn_on_action:
      then:
        lambda: !lambda |-
          id(min_humid_store).publish_state(0x7FFF);
    turn_off_action:
      then:
        lambda: !lambda |-
          id(min_humid_store).publish_state(500);
# Operating Mode
select:
  - platform: "tuya"
    enum_datapoint: 2
    options:
      0: Automatic
      1: Manual
      2: Timer
  - platform: "tuya"
    enum_datapoint: 23
    options:
      0: C
      1: F
number:
    min_value: -40
    max_value: 0x7FFF
    step: 1
    internal: True
    optimistic: True
    min_value: -40
    max_value: 0x7FFF
    step: 1
    internal: True
    optimistic: True
    name: "Minimum Temperature"
    min_value: -40
    max_value: 212
    step: 0.1
    lambda: !lambda |-
      return id(min_temp_store).state;
    set_action:
      then:
        lambda: !lambda |-
          id(min_temp_store).publish_state(x);
          int16_t max_temp = id(max_temp_store).state*10;
          int16_t min_temp = (int16_t)x*10;
          uint32_t min_max = ((int16_t)max_temp << 16) & min_temp;
          id(tuya_mcu).set_integer_datapoint_value(16, min_max);
    name: "Maximum Temperature"
    min_value: -40
    max_value: 212
    step: 0.1
    lambda: !lambda |-
      return id(max_temp_store).state;
    set_action:
      then:
        lambda: !lambda |-
          id(max_temp_store).publish_state(x);
          int16_t max_temp = (int16_t)x*10;
          int16_t min_temp = id(min_temp_store).state*10;
          uint32_t min_max = (max_temp << 16) & min_temp;
    min_value: 0
    max_value: 0x7FFF
    step: 1
    internal: True
    optimistic: True
    min_value: 0
    max_value: 0x7FFF
    step: 1
    internal: True
    optimistic: True
    name: "Minimum Humidity"
    min_value: 0
    max_value: 100
    step: 0.1
    lambda: !lambda |-
      return id(min_humid_store).state;
    set_action:
      then:
        lambda: !lambda |-
          id(min_humid_store).publish_state(x);
          uint16_t max_humid = id(max_humid_store).state*10;
          uint16_t min_humid = (uint16_t)x*10;
          uint32_t min_max = ((uint16_t)max_humid << 16) & min_humid;
    name: "Maximum Humidity"
    min_value: 0
    max_value: 100
    step: 0.1
    lambda: !lambda |-
      return id(max_humid_store).state;
    set_action:
      then:
        lambda: !lambda |-
          id(max_humid_store).publish_state(x);
          uint16_t max_humid = (uint16_t)x*10;
          uint16_t min_humid = id(min_humid_store).state*10;
          uint32_t min_max = (max_humid << 16) & min_humid;
  - platform: "tuya"
    name: "Backlight Brightness"
    number_datapoint: 44
    min_value: 0
    max_value: 100
    step: 1
    min_value: 0
    max_value: 0x7FFF
    step: 1
    internal: True
    optimistic: True
    name: "Manual Fan Speed"
    min_value: 0
    max_value: 10
    step: 1
    icon: "mdi:fan"
    lambda: !lambda |-
      return id(manual_fan_speed_store).state;
    set_action:
      then:
        lambda: !lambda |-
          id(manual_fan_speed_store).publish_state(x);
          id(tuya_mcu).set_raw_datapoint_value(101, {(uint8_t)x, 0, 0, 0, 0});
  - platform: "tuya"
    name: "Auto Fan On Speed"
    number_datapoint: 103
    min_value: 0
    max_value: 10
    step: 1
  - platform: "tuya"
    name: "Auto Fan Off Speed"
    number_datapoint: 104
    min_value: 0
    max_value: 10
    step: 1
output:
    type: float
    min_power: 0.1
    max_power: 1
    write_action:
      then:
        lambda: !lambda |-
           id(manual_fan_speed).publish_state((uint8_t)(state*10+0.5));
           id(tuya_mcu).set_raw_datapoint_value(101, {(uint8_t)(state*10+0.5), 0, 0, 0, 0});
climate:
  - platform: pid
    name: "PID Climate Controller"
    sensor: temp_c
    default_target_temperature: 23.3°C
    cool_output: fan_speed_scaled
    control_parameters:
      kp: 0.76394
      ki: 0.00219
      kd: 66.59221
    deadband_parameters:
      threshold_high: 0.5°C
      threshold_low: -1.0°C
      kp_multiplier: 0.5
      ki_multiplier: 0.5
      kd_multiplier: 0.5
      deadband_output_averaging_samples: 5
# button:
#   - platform: template
#     name: "PID Climate Autotune"
#     on_press:
#       - climate.pid.autotune: pid_climate
# interval:
#   - interval: 5s
#     then:
#       lambda: !lambda |-
#         id(tuya_mcu).set_boolean_datapoint_value(109, true);
Hey. Stumbled across your post while looking for solutions myself.
Does the existing screen and buttons still work after this mod?
I assume it still uses the OEM temp/rh sensor (plugged into the jack)?
Yep, the OEM screen / buttons still work just fine. I’m using the corded temp / humidity sensor with the unit.
Hi @CStoEE
Thanks for positing your work. Just to confirm, you unsoldered the existing WBR3 in the pircture and replaced it with a new ESP12F module soldering it to the same pins as the previous one?
Bit late to the party but for anyone in future looking I have gotten the device working in tuya-local and there is a PR in at the moment to add the config. I can completely understand replacing the control with an ESP as the Tuya implementation of this device is “unique” with things like the power boolean being backwards (true = off) and sensor info only being accessible as a base64 encoded lump of 16 bit values that needs a set of template sensors to extract.
inkbird-ivc-001W.yaml
name: InkBird Fan Controller
products:
  - id: 1oat7zv3bd9ylx2q
    manufacturer: Inkbird
    model: IVC-001W
entities:
  - entity: fan
    translation_key: fan
    dps:
      - id: 1
        # Yes it is backwards and yes its just as dumb as you are thinking it is
        type: boolean
        mapping:
          - dps_val: true
            value: "off"
          - dps_val: false
            value: "on"
      - id: 2
        type: string
        mapping:
          - dps_val: auto
            value: auto
          - dps_val: hand
            value: manual
          - dps_val: timing
            value: smart
      - id: 103
        type: integer
        range:
          min: 1
          max: 10
      - id: 132
        type: string
        optional: true
        # DP 132: Base64 Encoded Status String
        # To decode: Decode Base64 > Read bytes as Big Endian Integers (16-bit)
        # Byte 0    : Header/Padding (Skip)
        # Bytes 1-2 : Current Temp °C (x10)
        # Bytes 3-4 : Current Temp °F (x10)
        # Bytes 5-6 : Current Humidity % (x10)
        # Bytes 7-8 : Fan Speed (RPM)
        # Bytes 9-10: High Temp Alarm Setting °C (x10)
        # Bytes 11-12: Low Temp Alarm Setting °C (x10)
  - entity: number
    name: Target Temperature
    category: config
    icon: "mdi:thermometer-lines"
    dps:
      - id: 16
        type: integer
        unit: "°C"
        range:
          min: 0
          max: 100
  - entity: select
    translation_key: temperature_unit
    category: config
    icon: "mdi:temperature-celsius"
    dps:
      - id: 23
        type: string
        mapping:
          - dps_val: "c"
            value: "c"
          - dps_val: "f"
            value: "f"
  - entity: number
    name: Screen Backlight
    category: config
    icon: "mdi:brightness-6"
    dps:
      - id: 44
        type: integer
        unit: "%"
        range:
          min: 0
          max: 100
  - entity: number
    name: Temperature Calibration
    category: config
    icon: "mdi:thermometer-check"
    dps:
      - id: 113
        type: integer
        unit: "°C"
        range:
          min: -100
          max: 100
  - entity: number
    name: Humidity Calibration
    category: config
    icon: "mdi:water-check"
    dps:
      - id: 114
        type: integer
        unit: "%"
        range:
          min: -100
          max: 100
