Is the new inkplate 10 implementation in esphome working? I can add inkplate_10 under model but when running it on my inkplate 10 the screen only uses 2/3 of the screen. Is there a option for screen size that I missed?
Your yaml? Your logs?
Tested with the example code:
switch:
- platform: restart
- platform: gpio
pin:
mcp23xxx: mcp23017_hub
number: 9
inverted: true
name: "Inkplate Greyscale mode"
lambda: return id(inkplate_display).get_greyscale();
turn_on_action:
- lambda: id(inkplate_display).set_greyscale(true);
turn_off_action:
- lambda: id(inkplate_display).set_greyscale(false);
name: "Inkplate Partial Updating"
lambda: return id(inkplate_display).get_partial_updating();
turn_on_action:
- lambda: id(inkplate_display).set_partial_updating(true);
turn_off_action:
- lambda: id(inkplate_display).set_partial_updating(false);
- platform: adc
update_interval: never
attenuation: 11db
pin: 35
name: "Inkplate Battery Voltage"
lambda: |-
id(battery_read_mosfet).turn_on();
delay(1);
float adc = id(battery_voltage).sample();
id(battery_read_mosfet).turn_off();
return adc;
filters:
- multiply: 2
i2c:
mcp23017:
- id: mcp23017_hub
address: 0x20
binary_sensor:
- platform: status
- platform: gpio
name: "Inkplate Touch Pad 1"
pin:
number: 10
- platform: gpio
name: "Inkplate Touch Pad 2"
pin:
number: 11
- platform: gpio
name: "Inkplate Touch Pad 3"
pin:
number: 12
time:
- platform: sntp
font:
- file: "Helvetica.ttf"
display:
- platform: inkplate6
greyscale: false
partial_updating: false
update_interval: 60s
model: inkplate_10
ckv_pin: 32
sph_pin: 33
gmod_pin:
number: 1
gpio0_enable_pin:
number: 8
oe_pin:
number: 0
spv_pin:
number: 2
powerup_pin:
number: 4
wakeup_pin:
number: 3
vcom_pin:
number: 5
lambda: |-
it.fill(COLOR_ON);
it.print(100, 100, id(helvetica_48), COLOR_OFF, TextAlign::TOP_LEFT, "ESPHome");
it.strftime(400, 300, id(helvetica_48), COLOR_OFF, TextAlign::CENTER, "%Y-%m-%d", id(esptime).now());
it.strftime(400, 400, id(helvetica_96), COLOR_OFF, TextAlign::CENTER, "%H:%M", id(esptime).now());
if (id(system_status).state) {
it.print(700, 100, id(helvetica_48), COLOR_OFF, TextAlign::TOP_RIGHT, "Online");
} else {
it.print(700, 100, id(helvetica_48), COLOR_OFF, TextAlign::TOP_RIGHT, "Offline");
Awaiting your log, and knowing your esphome version may help.
