My fairly straightforward Inkplate project.
The goal was to have a status display in the hallway with actionable information. So to quickly see if the house is locked down, what coat to put on, etc.
The Inkplate is perfect for that. It updates every 30 seconds, which is fast enough. In The end I put all static information in one big 600x800 image. All symbols were captured in the right size (advance export) from the MDI icon site and then converted to black and white using the ImageMagick “convert” command. This is needed, because the icons don’t show otherwise unless you put the panel in grayscale mode.
At the start I had some problems doing the initial flash on the Inkplate, until I discovered that you have to give the flash command first and then press the reset button (on the back) of the Inkplate.
The case is 3D printed (using Inkplates own STL files). Had some quality issues with that, due to printer issues. I ended up sanding case down and painting it with “Vlek weg”, a product to mask stains on whitewashed walls. It dries very quickly (15mins). This does not give a wearproof finish (essentially the same as a wall), but since this is a no-touch display I’m not worried about that.
esphome:
esp32:
board: esp-wrover-kit
logger:
level: WARN
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Inkplate Fallback Hotspot"
password: !secret fallback_password
ap_timeout: 5min
captive_portal:
ota:
password: !secret ota_password
api:
password: !secret api_password
encryption:
key: !secret api_encryption
button:
- platform: restart
switch:
name: "Inkplate Partial Updating"
lambda: return id(inkplate_display).get_partial_updating();
turn_on_action:
- lambda: id(inkplate_display).set_partial_updating(true);
turn_off_action:
- lambda: id(inkplate_display).set_partial_updating(false);
- platform: wifi_signal
name: "WiFi Signal Inkplate"
update_interval: 300s
icon: mdi:signal
- platform: homeassistant
entity_id: sensor.netatmo_mondriaanlaan_tuin_temperature
name: "Minimum temperatuur"
entity_id: sensor.minimum_temperatuur
name: "Maximum temperatuur"
entity_id: sensor.maximum_temperatuur
entity_id: sensor.current_uv_index_rounded
entity_id: sensor.wallbox_portal_added_energy
entity_id: sensor.zonnepanelen_opgewekt_vandaag
name: "Stroom opgewekt"
entity_id: sensor.salderen_hoog
entity_id: sensor.salderen_laag
name: "temp woonkamer"
entity_id: sensor.woonkamer_temperature
entity_id: sensor.bijkeuken_temperatuur
entity_id: sensor.hal_temperature
name: "temp slaapkamer"
entity_id: sensor.slaapkamer_temperature
name: "temp badkamer"
entity_id: sensor.badkamer_temperature
name: "temp kamer BBBB"
entity_id: sensor.kamer_BBBB_temperature
name: "temp berging 1"
entity_id: sensor.berging_temperature
name: "temp kamer CCCC"
entity_id: sensor.kamer_CCCC_temperature
name: "temp kamer AAAA"
entity_id: sensor.kamer_AAAA_temperature
text_sensor:
- platform: wifi_info
ip_address:
name: "Inkplate IP Address"
icon: mdi:ip-network
mac_address:
name: "Inkplate MAC Address"
icon: mdi:expansion-card
entity_id: sensor.neerslag_voorspelling
attribute: next_event
entity_id: cover.poort
entity_id: cover.garagedeur
entity_id: sensor.wallbox_portal_status_description
entity_id: sensor.alphenaandenrijn_vandaag
name: "Locatie CCCC Thuis"
entity_id: input_text.locatie_CCCC
name: "Locatie BBBB Thuis"
entity_id: input_text.locatie_BBBB
name: "Locatie AAAA Thuis"
entity_id: input_text.locatie_AAA
name: "Locatie CCCC Away"
entity_id: person.CCCC
name: "Locatie BBBB Away"
entity_id: person.BBBB
name: "Locatie AAAA Away"
entity_id: person.AAAA
entity_id: fan.cvs_fan
attribute: percentage
i2c:
mcp23017:
- id: mcp23017_hub
address: 0x20
binary_sensor:
- platform: status
entity_id: binary_sensor.schuifpui
entity_id: binary_sensor.haldeur
name: "Licht woonkamer"
entity_id: light.woonkamer_2
entity_id: binary_sensor.keukenraam
entity_id: light.keuken_5
entity_id: binary_sensor.voordeur_2
entity_id: light.hal_2
entity_id: binary_sensor.slaapkamer
entity_id: binary_sensor.deur_slaapkamer
name: "Licht slaapkamer"
entity_id: light.slaapkamer_2
entity_id: binary_sensor.deur_badkamer
name: "Licht badkamer"
entity_id: light.badkamer_2
name: "Raam kamer BBBB"
entity_id: binary_sensor.studeerkamer_BBBB
name: "Deur kamer BBBB"
entity_id: binary_sensor.deur_kamer_BBBB
name: "Licht kamer BBBB"
entity_id: light.kamer_BBBB
name: "Raam berging 1"
entity_id: binary_sensor.berging
name: "Deur berging 1"
name: "Licht berging 1"
entity_id: light.berging
name: "Raam kamer CCCC L"
entity_id: binary_sensor.slaapkamer_CCCC_links
name: "Raam kamer CCCC R"
entity_id: binary_sensor.slaapkamer_CCCC_rechts
name: "Licht kamer CCCC"
entity_id: light.kamer_CCCC_2
name: "Raam kamer AAAA"
entity_id: binary_sensor.studeerkamer_AAAA
name: "Deur kamer AAAA"
entity_id: binary_sensor.deur_kamer_AAAA
name: "Licht kamer AAAA"
entity_id: light.kamer_AAAA
name: "Deur berging 2"
entity_id: binary_sensor.deur_berging_2
name: "Licht berging2"
entity_id: light.berging_2
entity_id: binary_sensor.waarschuwing
time:
- platform: sntp
font:
- file: "gfonts://Varela+Round"
glyphs: ["!","%","<",">","+","=",",","-","_",".",":","°","0","1","2","3","4","5","6","7","8","9","A","B","C","D","E","F","G","H","I","J","K","L","M","N","O","P","Q","R","S","T","U","V","W","X","Y","Z"," ","a","b","c","d","e","f","g","h","i","j","k","l","m","n","o","p","q","r","s","t","u","v","w","x","y","z"]
image:
- file: "icon/Inkplate.png"
type: BINARY
- file: "icon/deur.png"
type: BINARY
- file: "icon/garage_dicht.png"
type: BINARY
- file: "icon/garage_open.png"
type: BINARY
- file: "icon/lamp.png"
type: BINARY
- file: "icon/offline.png"
type: BINARY
- file: "icon/online.png"
type: BINARY
- file: "icon/poort_dicht.png"
type: BINARY
- file: "icon/poort_open.png"
type: BINARY
- file: "icon/raam.png"
type: BINARY
- file: "icon/waarschuwing.png"
type: BINARY
- file: "icon/icon_ok.png"
type: BINARY
- file: "icon/leeg.png"
type: BINARY
- file: "icon/bgg.png"
type: BINARY
- file: "icon/eerste.png"
type: BINARY
- file: "icon/tweede.png"
type: BINARY
- file: "icon/buiten.png"
type: BINARY
- file: "icon/niet_thuis.png"
type: BINARY
- file: "icon/icon_lock.png"
type: BINARY
- file: "icon/icon_pause.png"
type: BINARY
- file: "icon/icon_charging.png"
type: BINARY
- file: "icon/icon_power.png"
type: BINARY
- file: "icon/icon_wait.png"
type: BINARY
- file: "icon/icon_disconnected.png"
type: BINARY
- file: "icon/icon_battery_full.png"
type: BINARY
- file: "icon/fan_low.png"
type: BINARY
- file: "icon/fan_high.png"
type: BINARY
- file: "icon/gft.png"
type: BINARY
- file: "icon/pmd.png"
type: BINARY
- file: "icon/papier.png"
type: BINARY
display:
- platform: inkplate6
greyscale: false
partial_updating: true
update_interval: 30s
full_update_every: 20
rotation: 270
ckv_pin: 32
sph_pin: 33
gmod_pin:
mcp23xxx: mcp23017_hub
number: 1
gpio0_enable_pin:
number: 8
oe_pin:
number: 0
spv_pin:
number: 2
powerup_pin:
number: 4
wakeup_pin:
number: 3
vcom_pin:
number: 5
lambda: |-
it.fill(COLOR_ON);
it.image(0, 0, id(background), COLOR_OFF, COLOR_ON);
it.strftime(193, 75, id(varela_40), COLOR_OFF, TextAlign::TOP_RIGHT, "%H:%M", id(esptime).now());
it.strftime(193, 145, id(varela_40), COLOR_OFF, TextAlign::TOP_RIGHT, "%d-%m", id(esptime).now());
if (id(system_status).state) {
if(id(afval_vandaag).state == "gft") {
it.image(65, 215, id(icon_gft), COLOR_ON, COLOR_OFF);
if(id(afval_vandaag).state == "pmd") {
it.image(65, 215, id(icon_pmd), COLOR_ON, COLOR_OFF);
if(id(afval_vandaag).state == "papier") {
it.image(65, 215, id(icon_papier), COLOR_ON, COLOR_OFF);
if(id(afval_vandaag).state == "None") {
it.image(65, 215, id(icon_online), COLOR_ON, COLOR_OFF);
} else {
it.image(65, 215, id(icon_offline), COLOR_ON, COLOR_OFF);
if (id(waarschuwing).state) {
it.image(120, 215, id(icon_waarschuwing), COLOR_ON, COLOR_OFF);
} else {
it.image(120, 215, id(icon_ok), COLOR_ON, COLOR_OFF);
if (id(poort).state == "closed") {
it.image(65, 285, id(icon_poort_dicht), COLOR_ON, COLOR_OFF);
} else {
it.image(65, 285, id(icon_poort_open), COLOR_ON, COLOR_OFF);
if (id(garage).state == "closed") {
it.image(120, 285, id(icon_garage_dicht), COLOR_ON, COLOR_OFF);
} else {
it.image(120, 285, id(icon_garage_open), COLOR_ON, COLOR_OFF);
it.printf(368, 75, id(varela_40), COLOR_OFF, TextAlign::TOP_RIGHT, "%.1f", id(temp_outside).state);
it.printf(368, 75, id(varela_14), COLOR_OFF, TextAlign::TOP_LEFT, "°C");
it.printf(368, 145, id(varela_30), COLOR_OFF, TextAlign::TOP_RIGHT, "%.0f/%.0f", id(temp_min).state, id(temp_max).state);
it.printf(368, 145, id(varela_14), COLOR_OFF, TextAlign::TOP_LEFT, "°C");
it.printf(368, 215, id(varela_14), COLOR_OFF, TextAlign::TOP_LEFT, "min");
switch((int)id(uv_index).state) {
case 0 ... 2:
it.print(368, 215, id(varela_40), COLOR_OFF, TextAlign::TOP_RIGHT, "60+");
break;
case 3 ... 5:
it.print(368, 215, id(varela_40), COLOR_OFF, TextAlign::TOP_RIGHT, "<45");
break;
case 6 ... 7:
it.print(368, 215, id(varela_40), COLOR_OFF, TextAlign::TOP_RIGHT, "<25");
break;
case 8 ... 10:
it.print(368, 215, id(varela_40), COLOR_OFF, TextAlign::TOP_RIGHT, "<15");
break;
case 11 ... 12:
it.print(368, 215, id(varela_40), COLOR_OFF, TextAlign::TOP_RIGHT, " <10");
break;
it.printf(396, 285, id(varela_40), COLOR_OFF, TextAlign::TOP_RIGHT, "%5s", id(tijd_regen).state.c_str());
it.printf(570, 75, id(varela_40), COLOR_OFF, TextAlign::TOP_RIGHT, "%.0f", fabs(id(salderen_hoog).state));
if (id(salderen_hoog).state < 0) {
it.print(570, 75, id(varela_40), COLOR_OFF, TextAlign::TOP_LEFT, "-");
it.print(570, 75, id(varela_14), COLOR_OFF, TextAlign::TOP_LEFT, "kWh");
it.printf(570, 145, id(varela_40), COLOR_OFF, TextAlign::TOP_RIGHT, "%.0f", fabs(id(salderen_laag).state));
if (id(salderen_laag).state < 0) {
it.print(570, 145, id(varela_40), COLOR_OFF, TextAlign::TOP_LEFT, "-");
it.print(570, 145, id(varela_14), COLOR_OFF, TextAlign::TOP_LEFT, "kWh");
it.printf(570, 215, id(varela_40), COLOR_OFF, TextAlign::TOP_RIGHT, "%.0f", id(stroom_opgewekt).state);
it.print(570, 215, id(varela_14), COLOR_OFF, TextAlign::TOP_LEFT, "kWh");
it.printf(570, 285, id(varela_40), COLOR_OFF, TextAlign::TOP_RIGHT, "%.0f", id(auto_geladen).state);
it.print(570, 285, id(varela_14), COLOR_OFF, TextAlign::TOP_LEFT, "kWh");
if (id(wallbox).state == "Locked") {
it.image(472, 285, id(icon_locked), COLOR_ON, COLOR_OFF);
if (id(wallbox).state == "Paused") {
it.image(472, 285, id(icon_paused), COLOR_ON, COLOR_OFF);
if (id(wallbox).state == "Charging") {
it.image(472, 285, id(icon_charging), COLOR_ON, COLOR_OFF);
if (id(wallbox).state == "Ready") {
it.image(472, 285, id(icon_ready), COLOR_ON, COLOR_OFF);
if (id(wallbox).state == "Waiting for car demand") {
it.image(472, 285, id(icon_full), COLOR_ON, COLOR_OFF);
if (id(wallbox).state == "Disconnected") {
it.image(472, 285, id(icon_disconnected), COLOR_ON, COLOR_OFF);
if (id(wallbox).state == "Waiting in queue by Power Boost") {
it.image(472, 285, id(icon_wait), COLOR_ON, COLOR_OFF);
if (id(locatie_CCCC_away).state == "home") {
if (id(locatie_CCCC_thuis).state == "bg") {
it.image(268, 370, id(icon_bgg), COLOR_ON, COLOR_OFF);
if (id(locatie_CCCC_thuis).state == "1") {
it.image(268, 370, id(icon_eerste), COLOR_ON, COLOR_OFF);
if (id(locatie_CCCC_thuis).state == "2") {
it.image(268, 370, id(icon_tweede), COLOR_ON, COLOR_OFF);
if (id(locatie_CCCC_thuis).state == "Buiten") {
it.image(268, 370, id(icon_buiten), COLOR_ON, COLOR_OFF);
} else {
if (id(locatie_CCCC_away).state == "not_home") {
it.image(268, 370, id(icon_afwezig), COLOR_ON, COLOR_OFF);
} else {
it.printf(268, 370, id(varela_40), COLOR_OFF, TextAlign::TOP_LEFT, "%.5s", id(locatie_CCCC_away).state.c_str());
if (id(locatie_BBBB_away).state == "home") {
if (id(locatie_BBBB_thuis).state == "bg") {
it.image(65, 370, id(icon_bgg), COLOR_ON, COLOR_OFF);
if (id(locatie_BBBB_thuis).state == "1") {
it.image(65, 370, id(icon_eerste), COLOR_ON, COLOR_OFF);
if (id(locatie_BBBB_thuis).state == "2") {
it.image(65, 370, id(icon_tweede), COLOR_ON, COLOR_OFF);
if (id(locatie_BBBB_thuis).state == "Buiten") {
it.image(65, 370, id(icon_buiten), COLOR_ON, COLOR_OFF);
} else {
if (id(locatie_BBBB_away).state == "not_home") {
it.image(65, 370, id(icon_afwezig), COLOR_ON, COLOR_OFF);
} else {
it.printf(65, 370, id(varela_40), COLOR_OFF, TextAlign::TOP_LEFT, "%.5s", id(locatie_BBBB_away).state.c_str());
if (id(locatie_AAAA_away).state == "home") {
if (id(locatie_AAAA_thuis).state == "bg") {
it.image(472, 370, id(icon_bgg), COLOR_ON, COLOR_OFF);
if (id(locatie_AAAA_thuis).state == "1") {
it.image(472, 370, id(icon_eerste), COLOR_ON, COLOR_OFF);
if (id(locatie_AAAA_thuis).state == "2") {
it.image(472, 370, id(icon_tweede), COLOR_ON, COLOR_OFF);
if (id(locatie_AAAA_thuis).state == "Buiten") {
it.image(472, 370, id(icon_buiten), COLOR_ON, COLOR_OFF);
} else {
if (id(locatie_AAAA_away).state == "not_home") {
it.image(472, 370, id(icon_afwezig), COLOR_ON, COLOR_OFF);
} else {
it.printf(472, 370, id(varela_40), COLOR_OFF, TextAlign::TOP_LEFT, "%.5s",id(locatie_AAAA_away).state.c_str());
if (id(fan_status).state) {
if (id(fan_procent).state == "50") {
it.image(550, 450, id(icon_fan_laag), COLOR_OFF, COLOR_ON);
} else {
it.image(550, 450, id(icon_fan_hoog), COLOR_OFF, COLOR_ON);
} else {
it.image(550, 450, id(icon_leeg), COLOR_ON, COLOR_OFF);
it.printf(30, 570, id(varela_30), COLOR_OFF, TextAlign::TOP_CENTER, "%.0f", round(id(temp_woonkamer).state));
if (id(raam_woonkamer).state) {
it.image(10, 630, id(icon_raam), COLOR_ON, COLOR_OFF);
} else {
it.image(10, 630, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(deur_woonkamer).state) {
it.image(10, 690, id(icon_deur), COLOR_ON, COLOR_OFF);
} else {
it.image(10, 690, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(licht_woonkamer).state) {
it.image(10, 750, id(icon_lamp), COLOR_ON, COLOR_OFF);
} else {
it.image(10, 750, id(icon_leeg), COLOR_OFF, COLOR_ON);
it.printf(90, 570, id(varela_30), COLOR_OFF, TextAlign::TOP_CENTER, "%.0f", round(id(temp_keuken).state));
if (id(raam_keuken).state) {
it.image(70, 630, id(icon_raam), COLOR_ON, COLOR_OFF);
} else {
it.image(70, 630, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(licht_keuken).state) {
it.image(70, 750, id(icon_lamp), COLOR_ON, COLOR_OFF);
} else {
it.image(70, 750, id(icon_leeg), COLOR_OFF, COLOR_ON);
it.printf(150, 570, id(varela_30), COLOR_OFF, TextAlign::TOP_CENTER, "%.0f", round(id(temp_hal).state));
if (id(deur_hal).state) {
it.image(130, 690, id(icon_deur), COLOR_ON, COLOR_OFF);
} else {
it.image(130, 690, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(licht_hal).state) {
it.image(130, 750, id(icon_lamp), COLOR_ON, COLOR_OFF);
} else {
it.image(130, 750, id(icon_leeg), COLOR_OFF, COLOR_ON);
it.printf(210, 570, id(varela_30), COLOR_OFF, TextAlign::TOP_CENTER, "%.0f", round(id(temp_slaapkamer).state));
if (id(raam_slaapkamer).state) {
it.image(190, 630, id(icon_raam), COLOR_ON, COLOR_OFF);
} else {
it.image(190, 630, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(deur_slaapkamer).state) {
it.image(190, 690, id(icon_deur), COLOR_ON, COLOR_OFF);
} else {
it.image(190, 690, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(licht_slaapkamer).state) {
it.image(190, 750, id(icon_lamp), COLOR_ON, COLOR_OFF);
} else {
it.image(190, 750, id(icon_leeg), COLOR_OFF, COLOR_ON);
it.printf(270, 570, id(varela_30), COLOR_OFF, TextAlign::TOP_CENTER, "%.0f", round(id(temp_badkamer).state));
if (id(deur_badkamer).state) {
it.image(250, 690, id(icon_deur), COLOR_ON, COLOR_OFF);
} else {
it.image(250, 690, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(licht_badkamer).state) {
it.image(250, 750, id(icon_lamp), COLOR_ON, COLOR_OFF);
} else {
it.image(250, 750, id(icon_leeg), COLOR_OFF, COLOR_ON);
it.printf(330, 570, id(varela_30), COLOR_OFF, TextAlign::TOP_CENTER, "%.0f", round(id(temp_kamer_BBBB).state));
if (id(raam_kamer_BBBB).state) {
it.image(310, 630, id(icon_raam), COLOR_ON, COLOR_OFF);
} else {
it.image(310, 630, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(deur_kamer_BBBB).state) {
it.image(310, 690, id(icon_deur), COLOR_ON, COLOR_OFF);
} else {
it.image(310, 690, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(licht_kamer_BBBB).state) {
it.image(310, 750, id(icon_lamp), COLOR_ON, COLOR_OFF);
} else {
it.image(310, 750, id(icon_leeg), COLOR_OFF, COLOR_ON);
it.printf(390, 570, id(varela_30), COLOR_OFF, TextAlign::TOP_CENTER, "%.0f", round(id(temp_berging_1).state));
if (id(raam_berging_1).state) {
it.image(370, 630, id(icon_raam), COLOR_ON, COLOR_OFF);
} else {
it.image(370, 630, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(deur_berging_1).state) {
it.image(370, 690, id(icon_deur), COLOR_ON, COLOR_OFF);
} else {
it.image(370, 690, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(licht_berging_1).state) {
it.image(370, 750, id(icon_lamp), COLOR_ON, COLOR_OFF);
} else {
it.image(370, 750, id(icon_leeg), COLOR_OFF, COLOR_ON);
it.printf(450, 570, id(varela_30), COLOR_OFF, TextAlign::TOP_CENTER, "%.0f", round(id(temp_kamer_CCCC).state));
if (id(raam_kamer_CCCC_l).state || id(raam_kamer_CCCC_r).state) {
it.image(430, 630, id(icon_raam), COLOR_ON, COLOR_OFF);
} else {
it.image(430, 630, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(licht_kamer_CCCC).state) {
it.image(430, 750, id(icon_lamp), COLOR_ON, COLOR_OFF);
} else {
it.image(430, 750, id(icon_leeg), COLOR_OFF, COLOR_ON);
it.printf(510, 570, id(varela_30), COLOR_OFF, TextAlign::TOP_CENTER, "%.0f", round(id(temp_kamer_AAAA).state));
if (id(raam_kamer_AAAA).state) {
it.image(490, 630, id(icon_raam), COLOR_ON, COLOR_OFF);
} else {
it.image(490, 630, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(deur_kamer_AAAA).state) {
it.image(490, 690, id(icon_deur), COLOR_ON, COLOR_OFF);
} else {
it.image(490, 690, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(licht_kamer_AAAA).state) {
it.image(490, 750, id(icon_lamp), COLOR_ON, COLOR_OFF);
} else {
it.image(490, 750, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(deur_berging_2).state) {
it.image(550, 690, id(icon_deur), COLOR_ON, COLOR_OFF);
} else {
it.image(550, 690, id(icon_leeg), COLOR_OFF, COLOR_ON);
if (id(licht_berging_2).state) {
it.image(550, 750, id(icon_lamp), COLOR_ON, COLOR_OFF);
} else {
it.image(550, 750, id(icon_leeg), COLOR_OFF, COLOR_ON);
