Inline USB transformer - Physical install
I’m looking all over but can’t seem to find it. Is there an inline 120v to USB transformer for sale in the US anywhere? The idea is to avoid an outlet, and have 120v come in one side of the box, and a usb cord come in the other, mounted in the attic.
Hi Yaml-Stumped,
Thank you! But I did come up with an alternative that might be easier to wire across the house. Using a 24vac transformer right out of the breaker box, HVAC wire, and then another 24v to 5v transformer at the point. The latter being more expensive, but really easy to run the wire. It all depends on where “she” says to put the tablets. Still waiting on the 2nd location.
Make sure the 24v source has the wattage available to power several tablets if that’s where you are going.
A simple furnace 24AC transformer will probably not even power 1.
