Noob here. I’m trying to set up two Inovelli On/Off red series switches to control a 3-way light. Node 1 controls the load. We’ll call the other switch “Node 2”.
Using the Z Wave JS to MQTT Web UI, I found Node 2 > Groups and added a new association:
Group: On/Off Control
Target Node: Node 1
Node 2 can now turn off the load, but once it’s off, Node 2 is no longer responsive at all. I can only turn on the load with Node 1. Is this a wiring issue, or am I setting the associations incorrectly?
Any help would be appreciated.
