This is a blueprint for the Inovelli Black Series Dimmer, which has scene control capabilities specifically with the version 1.52 firmware found here: Index of /firmware/LZW31/Beta/1.52
Flash the LZW31_1.52.otz file to the device using Home Assistant (go to the Zwave JS integration, click devices, select the device, and then use the drop down next to the configure button to “Update”). I was unable to update the bin file, just the otz, but the bin file seems to just be the LED driver so just ignore that - it doesn’t matter.
Once that is complete, the device will be re-interviewed and should show “Firmware: 1.52” under Device info. That’s all that needs to be done. Simply create a new automation using the above blueprint and 1x paddle up/down, paddle hold up/down, and 1x config presses should work similar to the Red Series. Of note, 2x/3x/4x/5x paddle taps are not supported on the Black Series. Also, the Black Series On/Off switches reportedly do not and never will support scene control, only the dimmers for some reason.
Please let me know if you have any suggestions or improvements!
