Inovelli Blue Hubitat Maker API control not working
I am getting started in HA. I currently have all my zwave and zibgee devices connected to Hubitat and I have installed the Make API -HA and have all my devices showing in HA. All of them work except for my 1 Inovelli Blue 2-1 switch. The switch works perfectly in Hubitat. In HA when I toggle the controls to on, the physical switch turns on but then the toggle in HA turns off after about 1-2 seconds but the actual light switch stays on. The Logbook in HA does not record anything when I toggle the switch, but when I physically press the switch ON, the logbook records it but the device toggle switch continues to show it being off.
Inovelli Blue is running firmware 2.10 and the Hubitat driver is the most current version (dated 2024-05-30)
Any ideas on how to fix this? Any help would be greatly appreciated.
So I found that in HA I can automate if I use the Button 1 Press/Hold trigger, but the On/Off trigger does not work. I am not sure if this is a Hubitat driver issue or an issue in the HA sideā€¦
UPDATE: It looks like with the 2.08 Inovelli Blue firmware the On/Off Trigger in HA works fine but 2.10 does not.
