Inovelli Dimmer in Smart Bulb Mode, how to get changes to the bulb back to the switch
I’ve got an Inovelli red series dimmer in my daughter’s room and just installed some WiFi RGB bulbs. The dimmer is connected to Home Assistant via Zwave-js and the bulbs are connected via the Tuya integration. There are 4 WiFi bulbs and they are in a light group.
I have the dimmer in Smart Bulb mode and I’ve used the blueprint below to create an automation to control the lights from the switch. By itself, this works well and the lights turn on/off & dim from the switch and a double tap up sets brightness to 100% and resets the bulbs to white.
However, what I’m lacking is the ability to have changes to the bulbs reflected back to the switch. So if I turn on/off the bulbs or change the brightness via HA, the status of the switch doesn’t change. I created an automation to do this, but having both automations enabled seems to create loops and leads the overall control of the lights to be unreliable and unpredictable.
Any recommendation on how this can be solved so that the switch controls the bulbs and if the bulbs are changed via HA it is reflected in the switch?
Blueprint: Home Assistant Blueprint - Inovelli Red On/Off or Dimmer Scene to Actions · GitHub
Switch Automation:
alias: 'Kid''s Bedroom Light Sync: Switch'
description: ''
use_blueprint:
  path: mikemsd/inovelli_red_on_off_or_dimmer_scenes_zwavejs.yaml
  input:
    inovelli_switch: ece22faf34c95dadcaaf690e637a61e7
    config_action:
      - service: light.toggle
          entity_id: light.kids_strip_lights
    up_x2_action:
      - service: light.turn_on
          entity_id: light.kids_bedroom_lights
          brightness_pct: 100
          entity_id: light.kids_bedroom_light_bulbs
          kelvin: 2700
          brightness_pct: 100
    up_action:
    up_release_action:
          brightness: '{{ state_attr(''light.kids_bedroom_lights'',''brightness'') }}'
    down_release_action:
    down_action:
      - service: light.turn_off
Bulb Automation:
alias: 'Kid''s Bedroom Light Sync: Bulb'
description: ''
  - platform: state
  - platform: state
    attribute: brightness
condition: []
  - choose:
      - conditions:
          - condition: state
            state: 'on'
        sequence:
              brightness: >-
                state_attr('light.kids_bedroom_light_bulbs','brightness')
    default:
        data: {}
          entity_id:
            - light.kids_bedroom_lights
mode: queued
max: 10
Did you figure out how to get this working?
