I created an automation to run a LED notification on a inovelli blue switch when raining. It works but ram usage on home assistant grows the long it runs.
alias: Switch LED Rain
description: ""
- platform: state
entity_id:
- weather.openweathermap
to: rainy
- platform: state
entity_id:
to: pouring
condition: []
- repeat:
until:
- condition: or
conditions:
- condition: not
conditions:
- condition: state
entity_id: weather.openweathermap
state: rainy
- condition: state
state: pouring
- condition: device
device_id: 1f7f702209288990261a36ae50ec664b
domain: cover
entity_id: cover.garage_door
type: is_open
- type: is_moist
condition: device
device_id: 300cd8abc7839eb15d013cd250050eec
entity_id: binary_sensor.basement_water_sensor_iaszone
domain: binary_sensor
sequence:
- if:
- condition: device
type: is_on
device_id: 4ec9a5405f64a8c5b37d36018e065288
entity_id: light.office_switch_light
domain: light
then:
- type: issue_all_led_effect
domain: zha
effect_type: Slow_Chase
color: 170
level: 33
duration: 1
else:
domain: zha
color: 170
level: 3
duration: 1
mode: single
Hellis81
(Hellis81)
February 15, 2023, 12:31pm
2
Why are you repeating?
That automation is running all the time, really all the time.
Instead you can just trigger from: pouring and another from: rainy.
Then if that triggers turn off the light or whatever you want when it’s raining.
Or actually use a template:
{{ states('weather.openweathermap') not in ['pouring', 'rainy'] }}
Hellis81
(Hellis81)
February 15, 2023, 1:08pm
3
I believe something like this could work.
I have not added the basement sensor, don’t know what the other state is, is_dry?
That needs to be added as a trigger with trigger id no_rain also.
description: ""
mode: single
- platform: state
entity_id:
to: rainy
- platform: state
entity_id:
to: pouring
value_template: "{{ states('weather.openweathermap') not in ['pouring', 'rainy'] }} "
- platform: device
domain: cover
type: is_closed
condition: []
- choose:
- conditions:
- condition: trigger
- condition: device
domain: cover
type: is_open
- type: is_moist
condition: device
sequence:
domain: zha
color: 170
level: 33
duration: 1
- conditions:
sequence:
domain: zha
color: 170
level: 3
duration: 1
The repeating allows for the changing of the LED brightness if the switch is turned on/off while it is running.
Hellis81
(Hellis81)
February 15, 2023, 1:41pm
5
So does my example above. No need to loop.
The basement sensor and garage door conditions are there to prevent this automation from running over other automatons that are more important.
The two light sequences are both for rain. One is just brighter for when the switch is on. Hence why I use repeat.
If there is away around the repeat function thee “no_rain” condition would be to stop the LED effect.
Hellis81
(Hellis81)
February 15, 2023, 2:07pm
7
This shouldn’t be an issue. I believe your way of automating is recourse heavy and that is why you need to do this.
Normal automations does not have this issue.
Home Assistant is state based which means it’s very light weight if used properly.
Not only does your automation run all the time, I mean every millisecond but also it blasts out in the ZigBee network a new command.
So if both is for rain, are you expecting it to rain all the time? What will happen when it doesn’t rain?
Tell us what you want to happen and when and we can help you out.
Gotcha.
When it stops raining I want the LED to do nothing. Inovelli switches have a default LED color and brightness it will go to when the automation stops.
The “level: 33” brightness is for if the switch is on and the “level: 3” is for when the switch is off.
That effectively gives the LED auto dimming when the light in the room is turned on and off while running.
Also would it be better to move the garage door and basement sensor to the “contitions” as a “condition: not”
Hellis81
(Hellis81)
February 16, 2023, 5:59am
9
Ok… So what happens if you change the duration to lets say 60? Does it run for 60 seconds then?
What happens if you remove the duration? Does it go on forever?
Didn’t you just say you didn’t need them in the automation? Are these or not part of this automation?
60 is 60 seconds, 0 is invalid, and 255 is forever
I do need those conditions for the garage door and basement sensor that way this automation doesn’t play over another.
For example if the basement sensor detects water (i.e flooding) I want to make sure that automation for the LEDs is what runs.
Hellis81
(Hellis81)
February 16, 2023, 2:48pm
11
Post both automations then.
If we use 255 as the value and only change the state of the LED when needed then nothing will collide.
But I need to know what the other actions are
Those automatons will need to be reworded as well but I can do that once I have this one fixed.
Garage door LED
alias: Switch LED Garage Door
description: ""
- platform: device
domain: cover
type: opened
condition: []
- repeat:
until:
- condition: not
conditions:
- condition: device
domain: cover
type: is_open
sequence:
- if:
- condition: device
type: is_on
domain: light
then:
domain: zha
effect_type: Aurora
level: 33
duration: 1
color: 200
else:
domain: zha
duration: 1
level: 3
color: 200
effect_type: Aurora
enabled: true
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
mode: single
Basement water detection
alias: Water detected in basement
description: ""
- platform: state
entity_id:
- binary_sensor.basement_water_sensor_iaszone
for:
hours: 0
minutes: 0
seconds: 5
to: "on"
condition: []
- device_id: 7c8e66ec441be5978d5dec6bd0772523
domain: mobile_app
type: notify
message: Water detected in basement
- service: tts.google_translate_say
cache: false
entity_id: media_player.home_audio
- repeat:
until:
- condition: state
state: "off"
sequence:
domain: zha
effect_type: Fast_Siren
level: 100
duration: 1
color: 170
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
mode: single
This is untested and I added snow and lighting.
alias: Switch LED Weather
description: ""
- platform: state
entity_id:
- platform: state
entity_id:
- light.office_switch_light
condition:
- condition: not
conditions:
- type: is_moist
condition: device
- condition: device
domain: cover
type: is_open
- choose:
- conditions:
- condition: or
conditions:
- condition: state
state: rainy
- condition: state
state: pouring
sequence:
- if:
- condition: device
type: is_on
domain: light
then:
domain: zha
effect_type: Slow_Falling
color: 170
level: 33
duration: 255
else:
domain: zha
color: 170
level: 3
duration: 255
- conditions:
- condition: or
conditions:
- condition: state
state: snowy
- condition: state
state: snowy-rainy
sequence:
- if:
- condition: device
type: is_on
domain: light
then:
domain: zha
color: 255
level: 33
duration: 255
else:
domain: zha
color: 255
level: 3
duration: 255
- conditions:
- condition: or
conditions:
- condition: state
state: lightning
- condition: state
state: lightning-rainy
sequence:
- if:
- condition: device
type: is_on
domain: light
then:
domain: zha
color: 8
level: 33
duration: 255
else:
domain: zha
color: 8
level: 3
duration: 255
default:
domain: zha
effect_type: Clear
color: 170
level: 3
duration: 1
mode: single
Hellis81
(Hellis81)
February 17, 2023, 6:35am
14
I believe I got it all here.
This gives priority to water leak sensor. All other actions have water leak sensor as a condition to not interrupt the fast siren effect.
description: ""
mode: single
- platform: device
domain: cover
type: opened
- platform: device
domain: cover
type: closed
- platform: state
- platform: state
entity_id:
for:
hours: 0
minutes: 0
seconds: 5
to: "on"
- platform: state
entity_id:
for:
hours: 0
minutes: 0
seconds: 5
to: "off"
condition: []
- choose:
- conditions:
- condition: not
conditions:
- type: is_moist
condition: device
sequence:
- if:
- condition: device
type: is_on
domain: light
then:
domain: zha
effect_type: Aurora
level: 33
duration: 255
color: 200
else:
domain: zha
duration: 255
level: 3
color: 200
effect_type: Aurora
- conditions:
- condition: not
conditions:
- type: is_moist
condition: device
sequence:
domain: zha
duration: 255
level: 3
color: 200
effect_type: Aurora
- conditions:
- condition: template
value_template: "{{states('weather.openweathermap') not in ['pouring', 'rainy']}} "
- condition: not
conditions:
- type: is_moist
condition: device
sequence:
- if:
- condition: device
type: is_on
domain: light
then:
domain: zha
level: 33
duration: 255
color: 170
else:
domain: zha
duration: 255
level: 3
color: 170
- conditions:
value_template: >-
{{states('weather.openweathermap') not in ['snowy',
'snowy-rainy']}}
- condition: not
conditions:
- type: is_moist
condition: device
sequence:
- if:
- condition: device
type: is_on
domain: light
then:
domain: zha
level: 33
duration: 255
color: 255
else:
domain: zha
duration: 255
level: 3
color: 255
- conditions:
value_template: >-
{{states('weather.openweathermap') not in ['lightning',
'lightning-rainy']}}
- condition: not
conditions:
- type: is_moist
condition: device
sequence:
- if:
- condition: device
type: is_on
domain: light
then:
domain: zha
level: 33
duration: 255
color: 8
else:
domain: zha
duration: 255
level: 3
color: 8
- conditions:
sequence:
domain: mobile_app
type: notify
cache: false
domain: zha
level: 100
duration: 255
color: 170
- conditions:
sequence:
domain: zha
level: 100
duration: 1
color: 170
So if garage door is open and the weather changes to raining then rain will be displayed.
You could probably get another layer of priority in there but honestly, is one LED supposed to tell you everything?
Wouldn’t it be easier to use the TTS for water leak and garage door and have the light as the weather thing. After all your not looking at that light all the time are you?
The goal will be to replace switches all over the house with these also I like redundant notifications. I also want the dynamic LED brightness for when I have switches in the bedroom and living room. I don’t want to woken up or distracted by a super bright flashing LED. when the lights are off but I do want to be able to see them if the lights are on.
I believe I have everything working now. there are three automatons.
First is the water sensor (for basement flooding). This sends a push notification to my phone, sends a TTS alert to all google home speakers, and sets the switch LED to a red “siren” pattern at 100% brightness.
description: ""
- type: moist
platform: device
for:
hours: 0
minutes: 0
seconds: 0
- type: not_moist
platform: device
for:
hours: 0
minutes: 0
seconds: 0
condition: []
- choose:
- conditions:
- type: is_moist
condition: device
for:
hours: 0
minutes: 0
seconds: 0
sequence:
domain: mobile_app
type: notify
cache: false
domain: zha
color: 1
level: 100
duration: 255
- conditions:
- type: is_not_moist
condition: device
for:
hours: 0
minutes: 0
seconds: 0
sequence:
domain: zha
effect_type: Clear
color: 170
level: 1
duration: 1
mode: single
Next this the garage door notification. This sets the LED to purple “pulse” pattern and has two brightness’s (If Switch is on it is 33%, If switch is off 1%) and this will change “live”. It also has a condition not to run if the water sensor detects water. so not to over lap the previous automation.
description: ""
- platform: device
domain: cover
type: opened
- platform: device
domain: cover
type: closed
- platform: state
entity_id:
condition:
- condition: not
conditions:
- type: is_moist
condition: device
- choose:
- conditions:
- condition: device
domain: cover
type: is_open
sequence:
- if:
- condition: device
type: is_on
domain: light
then:
domain: zha
effect_type: Pulse
color: 190
level: 33
duration: 255
else:
domain: zha
effect_type: Pulse
level: 1
color: 190
duration: 255
- conditions:
- condition: device
domain: cover
type: is_closed
sequence:
domain: zha
effect_type: Clear
color: 170
level: 3
duration: 1
mode: single
Last is the weather LED. This has various colors and patterns based on the current weather condition. It also has the dynamic LED brightness and has conditions not to run if the water sensor detects water or if the garage door is opened.
description: ""
- platform: state
entity_id:
- platform: state
entity_id:
condition:
- condition: not
conditions:
- type: is_moist
condition: device
- condition: device
domain: cover
type: is_open
- choose:
- conditions:
- condition: or
conditions:
- condition: state
state: rainy
- condition: state
state: pouring
sequence:
- if:
- condition: device
type: is_on
domain: light
then:
domain: zha
color: 170
level: 33
duration: 255
else:
domain: zha
color: 170
level: 1
duration: 255
- conditions:
- condition: or
conditions:
- condition: state
state: snowy
- condition: state
state: snowy-rainy
sequence:
- if:
- condition: device
type: is_on
domain: light
then:
domain: zha
color: 255
level: 33
duration: 255
else:
domain: zha
color: 255
level: 1
duration: 255
- conditions:
- condition: or
conditions:
- condition: state
state: lightning
- condition: state
sequence:
- if:
- condition: device
type: is_on
domain: light
then:
domain: zha
color: 8
level: 33
duration: 255
else:
domain: zha
color: 8
level: 1
duration: 255
default:
domain: zha
effect_type: Clear
color: 170
level: 1
duration: 1
mode: single
I also have plans to add more in the future. my current plans are to add
person detected at front door (I have a nest doorbell)
If security system is armed (this would only be on switches next the exterior doors to prevent me form accidentally setting off the alarm)
More severe weather conditions (Tornado warning, winter weather advisory, severe cold/heat, etc)
