Zwave 1.4 & Open Zwave
Script
lzw45_pixel_effect:
alias: LZW45 Pixel Effect
description: Sets the pixel effects for the Inovelli LZW45 LED Strip
mode: restart
fields:
service:
description:
(required) The name of the service.
OpenZwave (Beta) -> 'ozw.set_config_parameter'
OpenZwave (1.4) -> 'zwave.set_config_parameter'
example: ozw.set_config_parameter
lzw45:
description: (required) The entity_id for the lzw45 LED Strip.
example: light.lzw45_light_strip_level
effect:
description: (required) The desired effect - static, blink, breath, color-wipe, color-wipe-reverse-inverse, color-wipe-random, random-color, single-dynamic, multi-dynamic, rainbow, rainbow-cycle, scan, dual-scan, fade, running-lights, twinkle, twinkle-random, twinkle-fade, twinkle-fade-random, sparkle, flash-sparkle, hyper-sparkle, strobe, blink-rainbow, chase-white, chase-color, chase-random, chase-rainbow, chase-flash, chase-flash-random, chase-rainbow-white, chase-blackout, chase-blackout-rainbow, color-sweep-random, running-color, running-red-blue, running-random, larson-scanner, comet, fireworks, fireworks-random, merry-christmas, circus-combustus, halloween, aurora
example: breath
brightness_pct:
description: (optional) The brightness percent, 0 - 99. Defaults to 99 if omitted.
example: 99
variables:
service: >
{{ service | default('ozw.set_config_parameter') }}
node_id: >
{%- if lzw45 is not defined %}
0
{%- else %}
{%- set node_id = state_attr(lzw45, 'node_id') %}
{{ node_id if node_id else 0 }}
{%- endif %}
byte1: >
{%- set effect = effect | default('static') | lower | replace(' ', '-') %}
{%- set effects = [
'static',
'blink',
'breath',
'color-wipe',
'color-wipe-reverse-inverse',
'color-wipe-random',
'random-color',
'single-dynamic',
'multi-dynamic',
'rainbow',
'rainbow-cycle',
'scan',
'dual-scan',
'fade',
'running-lights',
'twinkle',
'twinkle-random',
'twinkle-fade',
'twinkle-fade-random',
'sparkle',
'flash-sparkle',
'hyper-sparkle',
'strobe',
'blink-rainbow',
'chase-white',
'chase-color',
'chase-random',
'chase-rainbow',
'chase-flash',
'chase-flash-random',
'chase-rainbow-white',
'chase-blackout',
'chase-blackout-rainbow',
'color-sweep-random',
'running-color',
'running-red-blue',
'running-random',
'larson-scanner',
'comet',
'fireworks',
'fireworks-random',
'merry-christmas',
'circus-combustus',
'halloween',
'aurora'
{{ effects.index(effect) + 1 if effect in effects else 1 }}
byte2: >
{%- set pct = (brightness_pct | default(99)) | int %}
{%- if 0 <= pct <= 99 %}
{{ pct }}
{%- else %}
99
{%- endif %}
bytes: >
{{ byte2 * 2**8 + byte1 }}
sequence:
- condition: template
value_template: "{{ node_id != 0 }}"
- service: "{{ service }}"
node_id: "{{ node_id }}"
parameter: 31
value: "{{ bytes }}"
Service
service: script.lzw45_pixel_effect
service: ozw.set_config_parameter
lzw45: light.light_strip
effect: aurora
brightness_pct: 99
Zwave JS
Script
lzw45_pixel_effect:
mode: restart
fields:
lzw45:
example: light.light_strip
effect:
example: breath
brightness_pct:
example: 99
variables:
byte1: >
{%- set effects = [
'static',
'blink',
'breath',
'color-wipe',
'random-color',
'single-dynamic',
'multi-dynamic',
'rainbow',
'rainbow-cycle',
'scan',
'dual-scan',
'fade',
'running-lights',
'twinkle',
'twinkle-random',
'twinkle-fade',
'sparkle',
'flash-sparkle',
'hyper-sparkle',
'strobe',
'blink-rainbow',
'chase-white',
'chase-color',
'chase-random',
'chase-rainbow',
'chase-flash',
'chase-blackout',
'running-color',
'running-red-blue',
'running-random',
'larson-scanner',
'comet',
'fireworks',
'fireworks-random',
'merry-christmas',
'circus-combustus',
'halloween',
'aurora'
byte2: >
{{ pct }}
{%- else %}
99
{%- endif %}
bytes: >
sequence:
value_template: "{{ lzw45 is defined }}"
- service: zwave_js.bulk_set_partial_config_parameters
entity_id: "{{ lzw45 }}"
parameter: 31
Service
effect: aurora
brightness_pct: 99
