Inovelli LED Strip (LZW45) Quick Strip Effects Script
Hey everyone, I made a script that controls the LZW45 Quick Strip Effects.
Zwave 1.4 & OpenZwave
Script
lzw45_quick_strip_effect:
  alias: LZW45 Quick Strip Effect
  description: Sets quick strip effects for the Inovelli LZW45 LED Strip
  mode: restart
  fields:
    service:
      description:
        (required) The name of the service.
          OpenZwave (Beta) -> 'ozw.set_config_parameter'
          OpenZwave (1.4) -> 'zwave.set_config_parameter'
      example: ozw.set_config_parameter
    lzw45:
      description: (required) The entity_id for the lzw45 LED Strip.
      example: light.lzw45_light_strip_level
    effect:
      description: (required) The desired effect - 'off', 'solid', 'chase', 'fast-blink', 'slow-blink', 'fast-fade', 'slow-fade'
      example: slow-fade
    hue:
      description: (exclusive) The Hue.  Valid ranges are 0 to 360.  You cannot combine this with color_temp.
      example: 360
    color_temp:
      description: (exclusive) The color temperature (2700 - 6500).  You cannot combine this with hue.
      example: 2700
    brightness_pct:
      description: (optional) The brightness percent, 0 - 100.  Defaults to 100 if omitted.
      example: 10
    seconds:
      description: (optional) Duration of the effect in seconds (0 - 60 seconds).  Cannot be combined with 'minutes' or 'hours'.
      example: 1
    minutes:
      description: (optional) Duration of the effect in minutes (0 - 60 minutes).  Cannot be combined with 'seconds' or 'hours'.
      example: 1
    hours:
      description: (optional) Duration of the effect in hours (0 - 60 hours).  Cannot be combined with 'seconds' or 'minutes'.
      example: 1
    endless:
      description: (optional) Set to true if you want the effect to stay 'forever'.
      example: true
  variables:
    service: >
      {{ service | default('ozw.set_config_parameter') }}
    node_id: >
      {%- if lzw45 is not defined %}
        0
      {%- else %}
        {%- set node_id = state_attr(lzw45, 'node_id') %}
        {{ node_id if node_id else 0 }}
      {%- endif %}
    byte1: >
      {%- if hue is defined and color_temp is not defined %}
        {%- set hue = hue | int %}
        {%- set hue = hue if hue >= 0 else 0 %}
        {%- set hue = hue if hue <= 360 else 360 %}
        {{ (hue / 360 * 255) | int }}
      {%- elif color_temp is defined and hue is not defined %}
        {%- set color_temp = color_temp | int %}
        {%- set color_temp = color_temp if color_temp >= 2700 else 2700 %}
        {%- set color_temp = color_temp if color_temp <= 6500 else 6500 %}
        {{ ((color_temp - 2700) / (6500 - 2700) * 255) | int }}
      {% else %}
        0
      {%- endif %}
    byte2: >
      {%- set pct = (brightness_pct | default(100)) | int %}
      {%- if 0 <= pct <= 100 %}
        {%- if pct == 100 %}
          10
        {%- else %}
          {{ 128 + pct }}
        {%- endif %}
      {%- else %}
        0
      {%- endif %}
    byte3: >
      {%- set seconds = (seconds | default(0)) | int %}
      {%- set minutes = (minutes | default(0)) | int %}
      {%- set hours = (hours | default(0)) | int %}
      {%- set forever = endless | default(false) %}
      {%- if forever %}
        255
      {%- elif 0 < seconds <= 60 %}
        {{ seconds }}
      {%- elif 0 < minutes <= 60 %}
        {{ minutes + 60 }}
      {%- elif 0 < hours <= 60 %}
        {{ hours + 120 }}
      {%- else %}
        0
      {%- endif %}
    byte4: >
      {%- if hue is defined or color_temp is defined %}
        {%- set color_type = 64 if color_temp is defined else 0 %}
        {%- set effects = { 'off': 0, 'solid': 1, 'chase': 2, 'fast-blink': 3, 'slow-blink': 4, 'fast-fade': 5, 'slow-fade': 6 } %}
        {%- set value = 0 %}
        {%- set value = value + effects.get(effect, 0) %}
        {{ value + color_type }}
      {%- else %}
        0
      {%- endif %}
    bytes: >
      {{ byte4 * 2**24 + byte3 * 2**16 + byte2 * 2**8 + byte1 }}
  sequence:
  - condition: template
    value_template: "{{ node_id != 0 }}"
  - service: "{{ service }}"
      node_id: "{{ node_id }}"
      parameter: 21
      value: "{{ bytes }}"
Service
service: script.lzw45_quick_strip_effect
  service: ozw.set_config_parameter
  lzw45: light.lzw45_light_strip_level
  effect: slow-fade
  hue: 360
  brightness_pct: 100
  seconds: 20
Zwave JS
Script
  mode: restart
  fields:
    lzw45:
      description: (exclusive) The entity_id for the lzw45 LED Strip.
    effect:
      example: slow-fade
    color:
      description: (optional) hue or color_temp
      example: hue
    hue:
      example: 360
    color_temp:
      example: 2700
    brightness_pct:
      example: 10
    seconds:
      example: 1
    minutes:
      example: 1
    hours:
      example: 1
    endless:
      example: true
  variables:
    color_type: >
      {{ 64 if color == 'color_temp' else 0 }}
    byte1: >
      {%- if color_type == 0 %}
        {{ (hue | default(360) / 360 * 255) | int }}
      {%- else %}
        {{ ((color_temp | default(2700) - 2700) / (6500 - 2700) * 255) | int }}
      {%- endif %}
    byte2: >
          10
        {%- else %}
          {{ 128 + pct }}
        {%- endif %}
      {%- else %}
        0
      {%- endif %}
    byte3: >
      {%- if forever %}
        255
        {{ seconds }}
        {{ minutes + 60 }}
        {{ hours + 120 }}
      {%- else %}
        0
      {%- endif %}
    byte4: >
      {%- set effect = effect | default('static') | lower | replace(' ', '-') %}
    bytes: >
  sequence:
    value_template: "{{ lzw45 is defined }}"
  - service: zwave_js.bulk_set_partial_config_parameters
      entity_id: "{{ lzw45 }}"
      parameter: 21
Service
  effect: slow-fade
  hue: 360
  brightness_pct: 100
  seconds: 20
Hi Petro-
I don’t see zwave_js.set_config_parameter exposed as a service yet- at least as of 2021.2.1. Are you doing something tricky to make that work on your environment? I ask because I’d like to use this service to change LED color on some of my Red Series switches. It’s one of the last couple things I need to be fully functional on zwave-js. It’s nice to know that this is probably coming soon!
No, it’s not available in Zwave JS yet.
Also, this will not work with the Red Series switches. They use a different config paramter and the parameter changes are not 1 to 1.
Thanks for this!
Q: Can I use it with my Inovelli connected Smartthings?
Is this working with Zwave JS now? I just got a light strip but am having issues getting it to do any custom effects or pixel effects (from the other scripts you’ve provided). Not really sure where i am going wrong.
I was able to get it to do the chase-rainbow effect for one iteration, then it was just stuck in ‘rainbow’ mode. Really thought these would be easier to handle…
Check out the post on the inovelli forums
