I just installed a new ceiling fan and inovelli red series fan/light dimmer, the physical switch works great and I was able to add the node to home assistant, however, when I go to turn on the light it also activates the ceiling fan and there doesn’t seem to be a way to control the two independently of each other. I’ve gone through my entities and there’s only the single entry for the light. Is there a way to control the two individually?
Did you do this step?
Yes I followed that step, still the same problem. The node shows up and I can toggle it, the problem is there isn’t two separate entities for the fan and the light.
Not sure if you found the answer but I have 3 instances of the switch. It sounds like you’re using instance 1 which controls both the light and fan.
- Instance 1 (endpoint 0, or no endpoint): controls both the light and the fan
- Instance 2 (endpoint 1): controls the light
- Instance 3 (endpoint 2): controls the fan
