Hello, I am replacing some failing GE ZW4005 or Jasco 14291 with Inovelli LZW30 On/Off switches and I am ready to drop them in a lake…
I have been using HA for years without any issues with the Jasco/GE switches as Secure nodes and there is something wrong with Inovelli in which the lag and delay for turning a light on or off it can take several seconds or even close to a minute. If you try the same switch a few times they go nuts.
I was using HA in a Raspberry 4 and then switched to a regular PC i5 with 16 GB of RAM so it is not a hardware limitation of the host and I am using the AEON Labs ZW090 Z-Stick Gen5 stick. All the other remaining Jasco/GE switches work perfectly.
I have seen a multitude of posting about configuration changes and followed some of them but kind of lost if this is just not properly compatible or something I am missing in the configs.
I already have the following files in HA:
/opt/open-zwave/config/inovelli/lzw40.xml
/opt/open-zwave/config/manufacturer_specific.xml which contains:
<Manufacturer id="031E" name="Inovelli">
<Product type="0002" id="0001" name="LZW30-SN Switch Red Series" config="inovelli/lzw30-sn.xml"/>
<Product type="0004" id="0001" name="LZW30 Switch" config="inovelli/lzw30.xml"/>
<Product type="0001" id="0001" name="LZW31-SN Dimmer Red Series" config="inovelli/lzw31-sn.xml"/>
<Product type="0003" id="0001" name="LZW31 Dimmer" config="inovelli/lzw31.xml"/>
<Product type="0005" id="0001" name="LZW42 Multi-Color Bulb" config="inovelli/lzw42.xml"/>
<Product type="0006" id="0001" name="LZW41 Multi-White Bulb" config="inovelli/lzw41.xml"/>
<Product type="0007" id="0001" name="LZW40 Dimmable Bulb" config="inovelli/lzw40.xml"/>
<Product type="000d" id="0001" name="LZW60 4-in-1 Sensor" config="inovelli/lzw60.xml"/>
<Product type="000e" id="0001" name="LZW36 Fan/Light Dimmer" config="inovelli/lzw36.xml"/>
</Manufacturer>
Any other parameter to adjust?
Paul
