This blueprint allows you to easily create automations from the scene buttons from the Inovelli LZW36 Fan/Dimmer Switch. Long term Iโd like to create a single blueprint that could handle all Inovelli models and both OZW and zwave but since this is my first blueprint I wanted to start smaller.
blueprint:
description: |
Use this blueprint to create automations based on button presses for the LZW36 - Red Series Fan/Light Switch while using the OZW integration. I plan on expanding this to the other supported switches as well as an option for the legacy zwave integration but this is a start.
domain: automation
input:
light_switch:
description: The inovelli fan/dimmer switch that will trigger the scenes
selector:
entity:
integration: ozw
domain: light
light_button_twice:
name: Light Button Twice
description: Pick an action for when the light button is pressed twice.
selector:
light_button_thrice:
name: Light Button Three Times
description: Pick an action for when the light button is pressed three times.
selector:
fan_button_twice:
name: Fan Button Twice
description: Pick an action for when the fan button is pressed twice.
selector:
fan_button_thrice:
name: Fan Button Three Times
description: Pick an action for when the fan button is pressed three times.
selector:
variables:
device: !input "light_switch"
entity_node_id: "{{ state_attr(device,'node_id') }}"
- platform: event
event_type: ozw.scene_activated
- variables:
node_id: "{{trigger.event.data.node_id}}"
scene_id: "{{ trigger.event.data.scene_id }}"
scene_value_id: "{{ trigger.event.data.scene_value_id }}"
- service: ozw.set_config_parameter
node_id: "{{entity_node_id}}"
parameter: 24
value: 33819041
parameter: 25
value: 33819041
- choose:
- conditions:
- "{{ node_id == entity_node_id }}"
- "{{ scene_id == 2 }}"
- "{{ scene_value_id == 4 }}"
sequence: !input light_button_twice
- conditions:
- "{{ scene_value_id == 5 }}"
sequence: !input light_button_thrice
- conditions:
- "{{ scene_id == 1 }}"
sequence: !input fan_button_twice
- conditions:
sequence: !input fan_button_thrice
