🔴️ Inovelli RED Led Status Change for Garage + Door Lock [ex: August/MyQ/ZwaveJS] (zwave not required)
Scripts need to be installed. The scripts tab maybe let’s you do this … new script… yaml editor paste?
Also you can copy it to the system.
(On iPhone otherwise I could be more specific)
@jeeftor This solution has been rock solid for quite some time for me.
After upgrading to 2023.3, I am now seeing these errors in my logs that appears to be stopping the script with a SetValueFailed.
Anyone else see this and understand how to fix? What’s weird is the LED appears to still be changing for me despite the errors.
Logger: homeassistant.components.script.inovelli_led
Source: helpers/script.py:409
Integration: Script (documentation, issues)
First occurred: 08:30:08 (4 occurrences)
Last logged: 08:34:58
inovelli_led: Choose at step 2: choice 1: Error executing script. Error for call_service at pos 1: Node(node_id=18) - SetValueFailed: Unable to set value, refer to https://zwave-js.github.io/node-zwave-js/#/api/node?id=setvalue for possible reasons
inovelli_led: Error executing script. Error for choose at pos 2: Node(node_id=18) - SetValueFailed: Unable to set value, refer to https://zwave-js.github.io/node-zwave-js/#/api/node?id=setvalue for possible reasons
Logger: homeassistant.components.automation.inovelli_red_series_lzw31_sn_dimmer_led_notifications_based_on_combo_of_door_and_garage
Integration: Automation (documentation, issues)
First occurred: 08:30:08 (10 occurrences)
Last logged: 08:56:45
Auto - Mudroom - Security Light on Switch for Garage Doors Status: Choose at step 1: choice 3: Error executing script. Error for call_service at pos 2: Node(node_id=18) - SetValueFailed: Unable to set value, refer to https://zwave-js.github.io/node-zwave-js/#/api/node?id=setvalue for possible reasons
Auto - Mudroom - Security Light on Switch for Garage Doors Status: Error executing script. Error for choose at pos 1: Node(node_id=18) - SetValueFailed: Unable to set value, refer to https://zwave-js.github.io/node-zwave-js/#/api/node?id=setvalue for possible reasons
Auto - Mudroom - Security Light on Switch for Garage Doors Status: Choose at step 1: choice 1: Error executing script. Error for call_service at pos 2: Node(node_id=18) - SetValueFailed: Unable to set value, refer to https://zwave-js.github.io/node-zwave-js/#/api/node?id=setvalue for possible reasons
Auto - Mudroom - Security Light on Switch for Garage Doors Status: Choose at step 1: choice 2: Error executing script. Error for call_service at pos 2: Node(node_id=18) - SetValueFailed: Unable to set value, refer to https://zwave-js.github.io/node-zwave-js/#/api/node?id=setvalue for possible reasons
Source: components/automation/__init__.py:566
First occurred: 08:30:08 (5 occurrences)
Error while executing automation automation.inovelli_red_series_lzw31_sn_dimmer_led_notifications_based_on_combo_of_door_and_garage: Node(node_id=18) - SetValueFailed: Unable to set value, refer to https://zwave-js.github.io/node-zwave-js/#/api/node?id=setvalue for possible reasons
