Took a queue from @vbflo and created a blueprint for Inovelli Red Switches (LZW30-SN) which should also work with the Red Dimmer (but I don’t have one to test and would not have the hold up/down).
blueprint:
name: Inovelli Red Switches (LZW30-SN)
description: "Use this blueprint to create automations based on button presses for\
\ the LZW31-SN - Red Series Switch while using the OZW integration. \n"
domain: automation
input:
inovelli_switch:
description: The inovelli switch that will trigger the scenes
selector:
entity:
integration: ozw
domain: switch
light_button_on_1:
description: Pick an action for when the light button is pressed once.
default: []
selector:
action: {}
light_button_off_1:
default: []
selector:
action: {}
light_button_on_2:
description: Pick an action for when the light button is pressed twice.
default: []
selector:
action: {}
light_button_off_2:
default: []
selector:
action: {}
light_button_on_3:
description: Pick an action for when the light button is pressed three times.
default: []
selector:
action: {}
light_button_off_3:
default: []
selector:
action: {}
light_button_on_4:
description: Pick an action for when the light button is pressed four times.
default: []
selector:
action: {}
light_button_off_4:
default: []
selector:
action: {}
light_button_on_5:
description: Pick an action for when the light button is pressed five times.
default: []
selector:
action: {}
light_button_off_5:
default: []
selector:
action: {}
config_button:
description: Pick an action for when the config button is pressed one times.
default: []
selector:
action: {}
source_url: https://community.home-assistant.io/t/inovelli-red-switches-lzw30-sn/255324
variables:
device: !input 'inovelli_switch'
ozw_node_id: '{{ state_attr(device,''node_id'') }}'
mode: single
- platform: event
event_type: ozw.scene_activated
condition: '{{ trigger.event.data.node_id == (ozw_node_id | int) }}'
- variables:
scene_id: '{{ trigger.event.data.scene_id }}'
scene_value_id: '{{ trigger.event.data.scene_value_id }}'
- choose:
- conditions:
- '{{ scene_id == 3 }}'
- '{{ scene_value_id == 1 }}'
sequence: !input 'config_button'
- conditions:
- '{{ scene_id == 2 }}'
sequence: !input 'light_button_on_1'
- conditions:
- '{{ scene_id == 1 }}'
sequence: !input 'light_button_off_1'
- conditions:
- '{{ scene_value_id == 4 }}'
sequence: !input 'light_button_on_2'
- conditions:
sequence: !input 'light_button_off_2'
- conditions:
- '{{ scene_value_id == 5 }}'
sequence: !input 'light_button_on_3'
- conditions:
sequence: !input 'light_button_off_3'
- conditions:
- '{{ scene_value_id == 6 }}'
sequence: !input 'light_button_on_4'
- conditions:
sequence: !input 'light_button_off_4'
- conditions:
- '{{ scene_value_id == 7 }}'
sequence: !input 'light_button_on_5'
- conditions:
sequence: !input 'light_button_off_5'
