I’m pumped that this should work, I just can’t get it to work. I know there is a complex script for this but I’m just trying to start with the basics but I can’t make the Inovelli Dimmer LED flash red or do anything.
I think I just need a little guidance on my values and what goes where… I don’t want to use node red. I have nothing against node red but HA automations are good enough for me.
Using the above image you would need to set bitmasks ff, ff00, ff0000, and 7f000000. Once you set the final one, you would see the notification bar change
I heard pretty soon you WILL be able to set multiple partials one on swoop via set config parameter. It may even be available if you are on beta. I personally am using Zwave2JSMQTT add on as opposed to official add-on
However, I’m just going to wait if they are making changes to allow multiple config parameters at once.
I’ve never setup Zwave2JSMQTT, I am running MQTT for my tasmota / esphome devices. Would there be a lot of configuration changes required? You know what I will research that on my own. I won’t bug you for stuff thats probably on youtube.
I got it working, I don’t know if it was because I wasn’t setting all the properties and just 1 doesn’t work BUT here is the script to flash green indefinitely.
