Hi Everyone,
I’m having an issue with an Input Boolean not working, despite being pretty sure that I had it working in the past with some advice from @Vasiley
I have my Xiaomi Vacuum working with HA, and have it appearing twice in HomeKit, once for the switch (which successfully turns the vacuum on and off but does not report back to homekit when it is done) and one for the Input Boolean, which just does not control the Vacuum with either HA or Homekit.
I’d like to get the input boolean working, especially with HomeKit but at least in HA. I am assuming I have something set up incorrectly.
My knowledge level is medium, I don’t have a separate automations file or anything and would like to keep it all in configuration.yaml if possible
Does anyone have any hot tips on making this input boolean work? Here’s my config.
Thank you all
vacuum:
- platform: xiaomi_miio
host: 192.168.0.118
token: *PrettySureThisIsSecret*
xiaomi_aqara:
discovery_retry: 5
gateways:
- key: **SECRET too?**
input_boolean:
xiaomi_vacuum_cleaner:
switch:
switches:
value_template: '{{ states("input_boolean.xiaomi_vacuum_cleaner") }}'
turn_on:
service: vacuum.start
entity_id: vacuum.xiaomi_vacuum_cleaner
turn_off:
service: vacuum.return_to_base
