Input Boolean Automation Doesn't work
I have what I believe is very simple automation. I have a helper input boolean which is set through a toggle switch on the dashboard and I want to switch on a plug based on that input boolean. The Yaml for the automation is below and when I run the automation, the plug switches on but the automation is never triggered by the input boolean. Can anyone suggest what I’m doing wrong?
alias: Someone Comes Home
description: ''
  - platform: state
    entity_id:
      - input_boolean.someone_home
    to: 'On'
condition: []
  - type: turn_on
    device_id: 5446093d2e5896ceee8bcaf2a3b8ebe9
    entity_id: switch.smart_plug_coffee_machine_on_off
    domain: switch
mode: single
An input_boolean’s state values are represented in lowercase.
Replace this:
    to: 'On'
with this:
    to: 'on'
@123 I feel very stupid now - yes that was it and thank you!
