If the TV is smart then you might be able to see if it’s on.
If not then you can use the USB output, an ESP and a voltage divider to sense if it’s on or off
It can if the TV has an integration.
You could also measure its power consumption or ping it (if it has a network interface that turns off in standby).
If you have a TV with assumed state and you are using a remote I would suggest that you take a look at this:
You can make your own media_player entity for the TV.
