Is it possible to set the initial state to the last known state so that when HASS is restarted, the boolean resumes the last state it was set to?
Check out the recorder component. It will do what you’re looking to do
Yep, there it is! I missed it in the docs.
Thank you for your response!
Just as important (or maybe more important, since typically the recorder is enabled by default), do not set an initial state for the input_boolean. See Input Boolean Restore State.
