jjmkimera
(Jürgen Müller)
1
Dear Home Assistant Community,
I would very much appreciate if you could give me a hint how to solve the following problem:
How can I set my Input Boolean Status on the “Last known Status” (On / OFF) before an automation executed an automatic restart/reboot of hass.io ?
Thanks so much for a hint!
finity
2
how do you have your input booleans coded? do you have “initial: x” in your config for them?
if you do then they will always be in “x” state after restart. remove that line and they should keep the previous state.
jjmkimera
(Jürgen Müller)
3
Thanks so much! This Worked!!!
