Has anyone else noticed that their input_boolean mqtt switches have stopped working?
I have two HA controllers. They communicate via MQTT.
Since about a week ago, the mqtt switches set up on the master HA controller have malfunctioned. When I switch one on, it switches off after about 2 seconds. But the other HA controller shows that the slave input_boolean entities have been switched on. And when I switch on the input_boolean on the slave, it does not show up as switched on on the master HA controller.
All the input_select, input_datetime entities that I use are working fine.
All these entities use the same principle of automation subscribing and publishing. Here are examples:
- alias: MQTT publish input_boolean states
initial_state: 'true'
platform: state
entity_id:
- input_boolean.heater_controlled_by_thermostat
- input_boolean.pool_temp_calc
- input_boolean.pool_ice_avoidance
- input_boolean.pool_summer_timing
- input_boolean.safety_cut_offs
- input_boolean.pool_motion_alert
- input_boolean.no_swimming_today
service: mqtt.publish
data_template:
topic: "ha2/input_boolean/{{trigger.to_state.object_id}}/state"
payload: "{{ trigger.to_state.state | lower }}"
retain: true
- alias: MQTT subscribe input_boolean command
- platform: mqtt
topic: 'ha2/input_boolean/heater_controlled_by_thermostat/set'
- platform: mqtt
topic: 'ha2/input_boolean/pool_temp_calc/set'
- platform: mqtt
topic: 'ha2/input_boolean/pool_ice_avoidance/set'
- platform: mqtt
topic: 'ha2/input_boolean/pool_summer_timing/set'
- platform: mqtt
topic: 'ha2/input_boolean/safety_cut_offs/set'
- platform: mqtt
topic: 'ha2/input_boolean/pool_motion_alert/set'
service_template: "input_boolean.turn_{{trigger.payload | lower}}"
data_template:
entity_id: "input_boolean.{{trigger.topic.split('/')[2]}}"
And here is an example of an MQTT switch:
- platform: mqtt
name: "Pool pump timer during Summer"
icon: mdi:pool
state_topic: "ha2/input_boolean/pool_summer_timing/state"
command_topic: "ha2/input_boolean/pool_summer_timing/set"
optimistic: true
I can see using MQTT.fx that the topics are being published correctly in both directions.
I am using Supervisor version 235 on both Raspberry Pi’s. The master is running Raspbian Buster and Docker 19.03.12, and the slave is running HassOS 4.12.
If the other types of entities (input_datetime etc) are working ok might this be a bug, and if so please could anyone advise how I report this?
Thank you for your help.
