I use two input_boolean to trigger when my SO and I are going to go to sleep this way the house mode can go from home > someone asleep > night mode.
I use Appdaemon to trigger the input_select for the house mode which in turn triggers the respective YAML automation in HA.
I experimented with a restart to see if the documentation was write that on restart an input_boolean is suppose to maintain the last state if the initial flag is not set on the config file.
How can I fix this.
RESTORE STATE
If you set a valid value for `initial` this integration will start with state set to that value. Otherwise, it will restore the state it had prior to Home Assistant stopping.
