Input Boolean not Toggling On
Can anyone tell me why this isn’t working? I’ve tried all all sorts of things to try and remedy but I can’t seem to get it to trigger on it’s own. I’ve double checked the state value in the developer panel and current state is ‘tomorrow’. Thoughts?
alias: Boolean Switch - Bins Tomorrow
description: Toggle the Boolean Switch
  - platform: state
    entity_id: sensor.trash_day_2
    to: tomorrow
condition:
  - condition: state
    entity_id: input_boolean.trash_tomorrow
    state: 'off'
  - service: homeassistant.toggle
mode: single
It has to change from something else to tomorrow to trigger. If it was already tomorrow when you wrote the automation it won’t trigger.
Gotcha. Thanks! That might also explain why it didn’t fire this morning since I had it time bound to send the notification in early evening.
I’ll try changing the variable to test it tomorrow (when state = ‘today’)… I’ve never needed to use delay so is this syntax right?
  - platform: state
    to: tomorrow
condition:
  - condition: state
    state: 'off'
  - delay:
      hours: 15
      minutes: 0
      seconds: 0
      milliseconds: 0
mode: single
It is but you may want to avoid a delay this long as the delay won’t stay if HA is restarted or in fact if automations are reloaded.
A better option may be to use a time trigger at 15:00 and check to see if the trash is due tomorrow in the conditions.
You are a GENIUS! I can’t believe I didn’t think of that sooner. Thanks so much for helping out!
