I’ve had some great advice that the way to get a start button for the xiaomi vacuum in Homekit was to create an ‘input boolean’ (queue googling what that means whilst at work). I was able to stitch this together from an example posted and paste it into my configuration.yaml, but it is not working.
Could anyone that knows more than me please show me (in terms that an idiot might understand) how to edit this and make it work. The dream is to have a switch that shows up in Homekit that when switched ‘on’ triggers the vacuum.start service and when switched ‘off’ triggers the vacuum.return_to_base service.
just can’t see how to rewrite this in a way that will work!
The switch shows up in HomeKit now, but it doesn’t appear to trigger the Vac when it’s turned on/off. I get an error when I log into HA saying that “the following platforms and components could not be set up: input-boolean”.
If I’m honest, I’m still not totally sure how to get the logs out of HA. I put “logger:” in my configuration.yaml so I will take a look. My understanding is that the logs will show me specifically what is wrong.
One more question… there’s an artifact of the ol can-n-paste job that I did, you can see the “heatpump_upstairs_power” name under “switches:” should I be changing that to acuum.xiaomi_vacuum_cleaner or XiaomiVac?
I have the same use case, a simple switch to use in HomeKit. There’s actually no reason to use an input_boolean for that, you can get away with a templated switch. Here’s the single switch that works for me:
