I have a zxt-120 which I am using for my split AC system.
I like to control it with Alexa. “Alexa turn on Split”, “Alexa turn off Split”
So I create an input_boolean.Split and automate On to Set mode Cool and Off to set mode Off.
It works fine. The problem is when I turn on or off the unit with the remote directly. Now the split is on one state and the input_boolean is in another.
I had the same issue when I used to control these on SmartThings so I wrote a “Stateless Switch” device that would ignore it’s current state and always issue a change of state trigger.
So I researched “home assistant stateless input_boolean” and found instructions to set the following in customizations.yaml
# Stateless switch
input_boolean.split:
assumed_state: true
This created two buttons On and Off instead of the toggle switch in the UI.
The problem is that this doesn’t really make the switch stateless. Once you turn off the boolean, if you turn it off again it doesn’t trigger any action.
Is there a way to fix this or some other component I should be using?
The only solution I can come up with is rather complicated and makes the voice commands much harder to remember which my Wife will hate.
This solution involves two input_boolean one for On and one for Off. With automations that switch them to an Off state whenever they are turned on. So I would have
input_boolean.split_on
input_boolean.split_off
This would work, it looks weird/ugly in the UI and the voice commands would be annoying.
“Alexa, turn on split on” to turn on the split ac
“Alexa, turn off split off” to turn off the split ac (I would have to reverse the automation toggle for this one so it gets turned on whenever it is turned off)
I am hoping there is a better solution.
