Input button helper to run curl command
So, I’ve just created a input_button helper - with icon - and I’ve added the entity in Lovelace in a “multiple entities” card, so it can be clicked.
Goal is when it is clicked a CURL call (command line) is done.
How can I achieve this? Do I need to add it as a script? And if so: how and how do I link the helper to the script?
Thanks!
Example input_button automation in the docs.
A better option might be to create a template button and put your shell command call right in the button so you don’t need a separate automation.
Eg.
template:
  - button:
      - name: "My Curl Command"
        unique_id: my_curl_command
        press:
          - service: shell_command.my_curll_command
