Input button to run a script or activate a scene
:face_with_monocle: About this blueprint
Type of blueprint: AUTOMATION
What does it do?
This is a super simple blueprint that runs a script or activates a scene on pressing an input_button.
:gear: Configuration
Requirements
  • Nothing special.
Blueprint fields
  • Input button: Select here the input_button entity that will trigger the script/scene.
  • Script or scene: Choose a script or scene to be activated by the button.
:heavy_plus_sign: Other blueprints from the same author
:arrow_down: How to get this blueprint?
Click the badge to import this Blueprint:
Or you can also:
  • Import this Blueprint by using the forum topic URL
  • Copy-paste the content of the following frame in a new file inside your configuration's blueprint folder:
Blueprint YAML
blueprint:
  author: marc-romu
  domain: automation
  name: 'Input button: Run a script or activate a scene'
  description: >
    This is a super simple blueprint to make an 'input_button' entity to execute a script or activate a scene.
  input:
    input_button:
      description: 'REQUIRED. Input button to set up.'
      selector:
        entity:
          filter:
            domain: input_button
      name: Script or scene
      description: 'REQUIRED. Script to execute or Scene to activate on pressing the button.'
      selector:
        entity:
          filter:
            domain:
              - script
              - scene
mode: single
- platform: state
  entity_id: !input input_button
condition:
- alias: "Activate the script/scene"
  service: homeassistant.turn_on
    entity_id: !input action
Changelog
  • 2023-11-27: First release date!
