Input_datetime background sometimes white
I modified a theme and now the background of my input_datetime helpers is sometimes white and sometimes black. This means when I restart HA sometimes the background appears white and next time it turns out black or vice versa. Unfortunately I cannot find out which entry in the yaml I have to change. Thanks for any helping hand!
Here’s my yaml:
# Theme based on the iOS Dark Mode UI
# Creator: Juan - @juanmtech
# Website: https://www.juanmtech.com
# YouTube Channel: https://youtube.com/juanmtech
# My Home Assistant Config files: https://github.com/JuanMTech/Home_Assistant_files
iOS Dark Mode:
  # Header:
  app-header-background-color: var(--primary-background-color)
  app-header-text-color: rgb(229, 229, 234)
  # Main Interface Colors
  primary-color: "#4682b4"
  light-primary-color: var(--primary-color)
  primary-background-color: rgb(0, 0, 0)
  secondary-background-color: rgb(44, 44, 46)
  divider-color: rgb(44, 44, 46)
  accent-color: "#FF8C00"
  # Text
  primary-text-color: "#F8F8FF"
  secondary-text-color: "#F8F8FF"
  text-primary-color: var(--primary-text-color)
  disabled-text-color: rgb(72, 72, 74)
  # Sidebar Menu
  sidebar-icon-color: rgb(199, 199, 204)
  sidebar-text-color: var(--primary-text-color)
  sidebar-background-color: rgb(28, 28, 30)
  sidebar-selected-background-color: var(--primary-background-color)
  sidebar-selected-icon-color: "#4682b4"
  sidebar-selected-text-color: var(--sidebar-selected-icon-color))
  # Buttons
  paper-item-icon-color: "#4682b4"
  paper-item-icon-active-color: "#f8f8ff"
  # States and Badges
  state-icon-color: "#4682b4"
  state-icon-active-color: "#f8f8ff"
  state-icon-unavailable-color: var(--disabled-text-color)
  # Sliders
  paper-slider-knob-color: rgb(242, 242, 247)
  paper-slider-knob-start-color: var(--paper-slider-knob-color)
  paper-slider-pin-color: "#4682b4"
  paper-slider-active-color: "#4682b4"
  paper-slider-secondary-color: var(--paper-slider-active-color)
  # Labels
  label-badge-background-color: rgb(28, 28, 30)
  label-badge-text-color: rgb(242, 242, 247)
  label-badge-red: rgb(255, 69, 58)
  label-badge-green: rgb(48, 209, 88)
  label-badge-blue: "#4682b4"
  label-badge-yellow: rgb(255, 214, 10)
  label-badge-gray: rgb(72, 72, 74)
  # Cards
  card-background-color: rgb(28, 28, 30)
  ha-card-border-radius: "15px"
  ha-card-box-shadow: none
  paper-dialog-background-color: var(--card-background-color)
  paper-listbox-background-color: var(--card-background-color)
  paper-card-background-color: var(--card-background-color)
  # Switches
  switch-checked-button-color: rgb(242, 242, 247)
  switch-checked-track-color:  "#4682b4"
  switch-unchecked-button-color: rgb(242, 242, 247)
  switch-unchecked-track-color: rgb(99, 99, 102)
  # Toggles
  paper-toggle-button-checked-button-color: var(--switch-checked-button-color)
  paper-toggle-button-checked-bar-color: var(--switch-checked-track-color)
  paper-toggle-button-unchecked-button-color: var(--switch-unchecked-button-color)
  paper-toggle-button-unchecked-bar-color: var(--switch-unchecked-track-color)
  # Table
  table-row-background-color: rgb(28, 28, 30)
  table-row-alternative-background-color: rgb(44, 44, 46)
  data-table-background-color: rgb(0, 0, 0)
  # Dropdowns
  material-background-color: rgb(28, 28, 30)
  material-secondary-background-color: rgb(44, 44, 46)
  mdc-theme-surface: var(--secondary-background-color)
  # Pre/Code
  markdown-code-background-color: rgb(58, 58, 60)
  # Checkboxes
  mdc-checkbox-unchecked-color: rgb(174, 174, 178)
  mdc-checkbox-disable-color: var(--disabled-text-color)
  mdc-select-fill-color: rgb(28, 28, 30)
  mdc-select-ink-color: var(--primary-text-color)
  mdc-select-label-ink-color: var(--secondary-text-color)
  mdc-select-idle-line-color: var(--primary-text-color)
  mdc-select-dropdown-icon-color: var(--secondary-text-color)
  mdc-select-hover-line-color: var(--accent-color)
  # Input
  input-fill-color: var(--secondary-background-color)
  input-dropdown-icon-color: var(--secondary-text-color)
  input-ink-color: var(--primary-text-color)
  input-label-ink-color: var(--secondary-text-color)
  input-idle-line-color: var(--primary-text-color)
  input-hover-line-color: var(--accent-color)
