Input Datetime helper in automation
I added DateTime helper and I set switch off time.
Next, I have automation:
alias: Korytarz - wyłącz
description: ""
  - platform: time
    at: input_datetime.korytarz_wylaczenie
condition:
  - condition: template
    value_template: >-
      now().timestamp() >= state_attr('input_datetime.korytarz_wylaczenie', 'timestamp')
    enabled: true
  - service: switch.turn_off
    data: {}
      entity_id: switch.korytarz_glowne
mode: single
The condition is wrong, why? What I doing wrong?
Help please.
A template must be written in Jinja, without verifying the condition, it must be
    value_template: >-
      {{ now().timestamp() >= state_attr('input_datetime.korytarz_wylaczenie', 'timestamp') }}
The condition is also completely unnecessary because the the trigger ensures that already.
If that’s the entire automation and you don’t have any other triggers, you don’t need that condition — it’s duplicating the trigger.
Alternative way to write the condition:
condition:
  - condition: time
    after: input_datetime.korytarz_wylaczenie
I have also other automation to set input_DateTime helper:
alias: Korytarz - włącz
description: ""
  - platform: state
    entity_id:
      - sensor.corridor_sensor
    to: "1"
condition: []
  - if:
      - condition: state
        state: "off"
    then:
      - service: switch.turn_on
        data: {}
  - service: input_datetime.set_datetime
      datetime: "{{ (now().timestamp() + 60) | timestamp_custom('%Y-%m-%d %H:%M:%S') }}"
      entity_id: input_datetime.korytarz_wylaczenie
mode: single
I have a PIR sensor, who have active state only by 1 second while motion is detect.
I want to create automation: If active state is trigered by PIR sensor, switch.korytarz_glowne is turn on by 60 secound. If PIR sensor set next active state in this period, the switch.korytarz_glowne should be turn on 60 second from last active state.
What may be wrong?
