I’m following the docs and trying to create a script to set a datetime input to the current date/time but it’s giving me an error:
- service: input_datetime.set_datetime
entity_id: input_datetime.date_and_time
data_template:
datetime: "{{ now().strftime('%Y-%m-%d %H:%M:%S') }}"
Failed to call service input_datetime/set_datetime. Invalid datetime specified: {{ now().strftime('%Y-%m-%d %H:%M:%S') }} for dictionary value @ data['datetime']
tom_l
April 13, 2020, 6:17am
2
What you have done is correct according to the docs:
You should raise a new issue. https://github.com/home-assistant/core/issues
jocnnor
(Jim O'Connor)
April 13, 2020, 6:48am
3
Did you create the input_datetime.date_and_time object? Does it have both date and time?
Since your variables so closely match the docs, did you name it correctly?
They named theirs ‘both_date_and_time’ in the config, but then call input_datetime.date_and_time in the example for some reason.
# Example configuration.yaml entry
input_datetime:
both_date_and_time: # <----
name: Input with both date and time
has_date: true
has_time: true
# Sets date and time to date and time from datetime object (current date and time in this example)
# But in the e
entity_id: input_datetime.date_and_time # <-----
data_template:
AhmadK
(akasma74)
April 13, 2020, 6:50am
4
how about this
data_template:
123
(Taras)
April 13, 2020, 12:04pm
5
Has anyone been able to reproduce this error? I can’t; it works for me.
Testing Procedure
I created this input_datetime:
input_datetime:
dt1:
name: Date Time 1
has_date: true
has_time: true
initial: "2019-05-01 07:30"
and these two scripts:
#script:
set_dt1_a:
alias: version a
sequence:
entity_id: input_datetime.dt1
data_template:
set_dt1_b:
alias: version b
sequence:
data_template:
Executing either of the two scripts correctly sets input_datetime.dt1
to the current date and time. The system log contains no warnings or errors.
EDIT
Tested with Home Assistant Core 0.108.0 and 0.108.3.
Looks like it was due to the fact I was using the GUI to build the automation. If I use automation.yaml and use data_template it works.
Thanks all for looking at this!
AhmadK
(akasma74)
April 13, 2020, 4:41pm
7
I’d suggest to open a new issue on Github if you use a reasonably new HA and can reproduce the issue with Automation editor.
It seems that I have the same issue, even I edit the script in Script.yaml. Can anybody help me? I got the same error message:
home assistant Failed to call service script Invalid time specified: for dictionary value @ data[‘time’]
while my definition is:
input_datetime:
get_up_time:
has_date: false
has_time: true
test:
alias: Test
sequence:
time: >
{% if is_state('WorkdayInDE', 'on') %}
'08:00:00'
{% else %}
'08:30:00'
{% endif %}
entity_id: input_datetime.get_up_time
mode: single
after the change below, it works
test:
alias: Test
sequence:
data_template:
time: '{% if is_state("WorkdayInDE", "on") %}08:00:00{% else %}08:30:00{% endif %}'
mode: single
