Input_datetime with has_date: false not convert as_timestamp
Hello.
I am trying to convert data from input_datetime entity to timestamp format:
{{ as_timestamp(states(‘input_datetime.both_date_and_time’))}}
But for some reason this is only possible if the input_datetime entity has both a date and a time
When has_date: false, this causes an error.
Maybe this conversion can be implemented in some other way?
All input_datetimes have a timestamp attribute, so:
{{ state_attr('input_datetime.time_only', 'timestamp') }}
Is there a way to convert just a time into the next timestamp that time will occur? I am making a coffee timer and want to set it to go off at 6:00am. I want to make a card that will display that the coffee will be made at (If the current day is Sunday) Monday at 6:00am
Essentially I want to add the date to a time that will display the next occurrence of that time.What will the full timestamp/date be the next time it’s 6:00am.
If I try to do a conversion on the above, it sets the date to 1/1/1970 at 1am
Thanks in advance!
